Old 11-13-2004, 09:50 PM   #1
Send a message via AIM to Hypnomagic
Default Rear Tires for Xray Factory RUBBING! HELP
I notice there are two holes on the rear shock arms for the Xray FActory kit. I am trying to run 28's on the back but the cause rubbing if i mount on the outer holes. Anyone have any suggestions as to how what i can do if i want to run 28 's and get the mount on the lower arms as far out as possible!
Hypnomagic is offline   Reply With Quote
Old 11-13-2004, 10:03 PM   #2
I run a FK. You have to remove 2 to 3mm of material off the arm where the shock mounts to the arm.
Hondaguy is offline   Reply With Quote
Rubbing alcohol to clean a body bigdog xxx-s Painting, Designs, Graphics and Photography 3 12-28-2007 09:27 PM
batteries rubbing Hayden Electric On-Road 4 08-01-2006 07:07 AM
CVD's rubbing scotwithonly1t Electric On-Road 3 12-29-2004 09:18 PM
pipe rubbing on Lexan corvettecrazy Electric Off-Road 11 07-19-2003 11:47 PM
savage.21 header rubbing gunyadown Rookie Zone 0 05-14-2003 04:46 PM
SEO by vBSEO 3.5.0
