Corally HMX
#62
Are they any changes from the prototype? The rear end looks real flexy, I hope they have done some changes there. And I really hope that you can fit gear diffs like I have on my 09. It have really been a big improvement on the lap times. You can´t be competitive with a ball diff in mod.
#63
On the prototype that I have been running, I have the Spec R TAO5 37 tooth gear diffs front and rear. I had to run the 510 front belt. Everything dropped in flawlessly. I had to remove 3mm from each outdrive so I could use all Corally cvds. Corally USA is just completing a gear diff package that will include both gear diffs, the 510 front belt and the outdrives already machined down 3mm. Corally is working on a gear diff for the HMX. I am told to look for it in early 2012.
Thanks - Brad
Thanks - Brad
#64
brad jossens
#65
Thanks - Brad
Thanks - Brad
#67
#68
#69
I like the alloy shocktowers.. But is the place where the bodyposts are going to be not a strange place? I think it's going to be on the roof of the body? or is there an other solution?
#75
