Old 12-14-2011, 01:44 AM   #106
spacendeman's Avatar
Send a message via MSN to spacendeman
nice that you like it!
I look to read about the test!
and do you have pictures of the car with the 07 shocktowers?
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 12-16-2011, 07:20 AM   #107
Here as I said some better pictures of the car.
Currently:
Old 12-16-2011, 09:33 AM   #108
Holmenkollen's Avatar
I canīt get the rear shocks long enough for correct droop seetings. Theyīre too short.
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 12-16-2011, 09:39 AM   #109
There is comming large ball ends voor de shockshaft soon. I turned the ballend very loose..
Currently:
Old 12-18-2011, 09:15 AM   #110
roger999's Avatar
hi anyone knows about retail price?
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 12-18-2011, 09:21 AM   #111
I thought limspeed.nl had it for 459euro?
Currently:
Old 12-19-2011, 04:51 AM   #112
FunkyDunky's Avatar
All,
I know of a couple of these kits brand new unbuilt up for sale in the UK. If you want one please inbox. sensible offers only. pictures etc can be supplied.
FunkyDunky is offline   Reply With Quote
Old 12-20-2011, 06:15 AM   #113
Originally Posted by FunkyDunky View Post
All,
How have you got these before the UK importer ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 12-20-2011, 12:10 PM   #114
FunkyDunky's Avatar
They come via them but direct from the factory, they sponsor a summer series in the UK and they were the prizes for winning. I have my tools out ready to start building so peps better get in quick if they want it unbuilt. I love building kits
:-D
Old 12-20-2011, 12:13 PM   #115
Smile Ceramic HMX Bearing Kit
We have just released our ceramic ball bearing kit for the Corally HMX. Only $89.99 with FREE shipping worldwide! Thanks to everyone who requested we make this bearing kit. Hope you enjoy!
ACER Racing: the Fastest, Smoothest, Lightest & HARDEST BALLS in the INDUSTRY.
acerracing is offline   Reply With Quote
Old 12-20-2011, 01:13 PM   #116
And in the mail almost before I'd ordered.
Super prompt service.
Peter
Pedro 51 is offline   Reply With Quote
Old 12-20-2011, 08:47 PM   #117
:-D
Ah the STCC , nice prizes.
Old 12-21-2011, 09:56 AM   #118
One light car, way below 1350g with steel screws, steel axles and two geardiffs.
http://rcblogg.wordpress.com/
Old 12-22-2011, 05:00 AM   #119
C van der Hagen's Avatar
Do you use the tamiya suspension parts?
What geardiffs do you use?
C van der Hagen is offline   Reply With Quote
Old 12-22-2011, 05:13 AM   #120
Yes. I canīt get enough steering throw with Corally parts, the steering knuckles hit the swaybar ball cup. You can dremel the knuckles and ball cup but I donīt think you can get same amount of steering throw as with Tamiya parts. If you are using Corally parts use the 4 degree alu caster block, itīs thinner than the 3 degree plastic = more throw.
I use Spec-R TA05 37t geardiffs. You have to use a 189 mm rear belt with this setup and a 37t front pulley if youīre using a spool. Otherwise you get some overdrive....
If youīre using the geardiffs with the Corally suspension you have to cut off 3mm on the geardiff outdrives and drill the hole a bit to avoid binding. Tamiya driveshafts are shorter so this is not a problem with Tamiya suspension.
You also have to trim one of the geardiff sides otherwise the swaybar alu. mount will interfere. Itīs a bit of work to make it all fit nicely but you canīt compete in modified nowadays with a ball diff....
Corally is coming out with a gear diff soon.
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 07:59 AM
SEO by vBSEO 3.5.0
