Old 01-19-2014, 12:05 PM   #436
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Tamiya used the same dcj's for all their cars.
TAM42216
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 01-20-2014, 05:20 AM   #437
Jimmy Morris's Avatar
TAM42216
http://www.superiorhobbies.com/store...int+Shaft+44mm
Jimmy Morris is offline   Reply With Quote
Old 02-05-2014, 10:19 PM   #438
Rick Pfeilstick's Avatar
Is corally dead?
- THREE NINE-JESSPEED- DURANGO-FANTOM-XRAY-CRC-
Rick Pfeilstick is offline   Reply With Quote
Old 02-05-2014, 10:49 PM   #439
rosko's Avatar
Once toso left corally left with him
rosko is offline   Reply With Quote
Old 02-06-2014, 01:13 AM   #440
Corally was just bought by an investment group, so will see what happens with that. I think that the HMX does not look good at all and maybe other people feel the same. It is also discouraging having to buy the carbon fiber shock towers which should have been included in the kit. I know that you do not need them, but all the team drivers have them on the their cars and it makes it easier to follow the set-ups. One thing that I always hated was not being able to adjust the belt tension at the diff and using other manufactures parts on the car. The coolest thing they have come out with is their new gear diff, I think this was a great idea and they made it usable on other car as well. I am surprised that no other manufacturer has look at this design.
Patrick
XCELL is offline   Reply With Quote
Old 02-06-2014, 05:33 AM   #441
Chaz955i's Avatar
Patrick
Hopefully this doesn't lead to a line of Corally branded generic Asian cars like a lot of the other stuff out there. Phi was a really cool car at the time if not a bit fragile in the plastic department. Lost interest in their touring products after that.
Chaz955i is offline   Reply With Quote
Old 02-14-2014, 07:58 PM   #442
Is there a cheaper alternative to the corally front spool?
Canuck5902 is offline   Reply With Quote
Old 03-20-2014, 09:57 AM   #443
gdiddy's Avatar
Default Gear Diff
Can the SGX gear diff be used in any other Touring car other than the HMX?
The desired effect is what you get when you improve your interplanetary funksmanship.
gdiddy is offline   Reply With Quote
Old 03-20-2014, 12:45 PM   #444
yes, they make a tamiya 37t pulley for it.
The long awaited SGX Gear Differential 37 Teeth Pulley has arrived. With this Pulley you can use the innovative Corally SGX Gear Diff on Tamiya, Hot Bodies, etc...
#79669 SGX Gear Differential 37 Teeth Pulley - incl. 4 pcs M2 x 5 PH (1 pc.)
#79674 SGX Gear Differential incl. 37T Pulley - For Tamiya ao. (1 set)
it won't provide a direct link but its on www.corally.com
Old 03-26-2014, 11:21 AM   #445
gdiddy's Avatar
Default Availabilty
Where and when will this items be available for purchase?
Old 03-27-2014, 05:09 AM   #446
call superior hobbies and ask for tj.
Old 04-04-2014, 07:11 PM   #447
Default corally ?
Were are you corally? Have you givin up yet.
Old 08-09-2014, 06:29 PM   #448
Anyone try shumacher spec r 36 tooth gear diffs in a hmx?
Old 08-09-2014, 11:35 PM   #449
oldrcr's Avatar
Trader Rating: 43 (100%+)
Default Corally gear diff
The Corally straight cut gear diff is not a new design. I had made one of this same design to experiment for use in slot cars and I think I saw it in the rear axle of a 1/8 nitro rear drive pan car as well. I will have to see if I can find any info on it. Had a friend who had the chassis, wonder if its still sitting in storage somewhere... Anyway, this would have been in the late 70's early 80's.
-a
Alxd - Seattle RC Racers - AWESOMATIX - Having Fun :-)
oldrcr is offline   Reply With Quote
Old 09-02-2014, 08:22 PM   #450
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
What ever happened to Corally Jack the Gripper TC-2 ?
Is it like the PSL from Starbucks, only available in the fall/winter
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 06:59 AM
