Old 09-26-2013, 07:42 AM   #421
Default Gear diffs
I have the 1st HMX chassis, i just installed gear diffs in the front and rear.
What weight of oil should i use? mainly racing on medium to high grip carpet.
At present runing car as standard with 80 shock oil(integy) with corally blue syrup in the rear.
Stel
Monty Mole is offline   Reply With Quote
Old 09-26-2013, 08:07 AM   #422
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Stel
As far as gear diffs go in the front I would run either some type of putty or the gravity 2.5 million in the front and in the rear im not sure about the that because I still use the spec r but I know alot of guys around here run the corally red. If you have a spec r diff though start at 2000 and go up from there. Thanks!
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 10-21-2013, 02:40 PM   #423
Rick Pfeilstick's Avatar
Default vegas set ups
any Vegas set ups. just wondering ?
- THREE NINE-JESSPEED- DURANGO-FANTOM-XRAY-CRC-
Rick Pfeilstick is offline   Reply With Quote
Old 10-21-2013, 02:58 PM   #424
haywood's Avatar
Trader Rating: 48 (100%+)
Rick... You already are super dialed! No need for any setup help!
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is online now   Reply With Quote
Old 11-20-2013, 09:17 AM   #425
Default smallest spur gear for hmx
Hi Guys,
as above what is the smallest spur can you use for the 1st version of the HMX.
i am racing 17.5t thunderpower motor and tekin rs esc. on carpet 18mx12m track sometime technicle,, so need rollout (FDR).
Stel.
Old 11-22-2013, 09:30 AM   #426
Corally USA's Avatar
We have run an 82t before and it fits fine, although it's super small and you're limited in pinion sizes that you can run. You may be able to go smaller but we've never had any need to try that.
CorallyUSA.com - SpecializedRC.com - SXT - Superiorhobbies.com
Corally USA is offline   Reply With Quote
Old 11-22-2013, 07:39 PM   #427
Hey corally have you finished your super trick steering upgrade yet?
Old 11-22-2013, 09:41 PM   #428
Trader Rating: 9 (80%+)
Hey Do Use Know Were I Can Get Some Corally 3x6mm / 3x8mm FH Torx Screws
Dan-Dan Team-X is offline   Reply With Quote
Old 11-23-2013, 09:24 AM   #429
Bell cranks are coming along, they're almost done, just want to get some more testing done. We do have the new steering blocks that change the ball stud location and allow for double jointed driveshafts available though. Both the blocks and driveshafts, those have helped tremendously.
We have those screws in stock, so give us a call on Monday or Superior Hobbies is open today and can take your order, 407-824-9299. Or email info@superiorhobbies.com if you're international.
Old 12-04-2013, 08:18 AM   #430
spacendeman's Avatar
Send a message via MSN to spacendeman
Did any of you guys tried this car in modified? and how did that go?
Thanks for the input.
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 12-04-2013, 11:47 AM   #431
Jimmy Morris's Avatar
A few of us in florida have been running modified on asphalt and its been going pretty well. With limited testing the cars are pretty close. Everyone who drives my car, including die hard xray supporters, really like how it drives.
www.superiorhobbies.com
Jimmy Morris is online now   Reply With Quote
Old 12-04-2013, 11:51 AM   #432
That is good to read!
How about the wear of the axles? Do you drive the steel shafts?
And with geardiff?
The car itself is durable for modified?
Currently:
Old 01-14-2014, 06:07 PM   #433
What drivesafts fit in a hmx? Thinking of a upgrade.
Old 01-18-2014, 01:08 PM   #434
tamiya or spec r double joint shafts in the front with the src aluminum steering blocks.
http://corallyusa.com/2013/05/specia...631-src79631c/
Old 01-19-2014, 11:01 AM   #435
Thanks. What tamiya shafts? Maybe a part #
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 06:59 AM
