Old 12-16-2012, 06:05 AM   #391
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by pete68 View Post
where in the us or canada corally is available !!!
call these guys-
http://www.superiorhobbies.com/store...1%3A10+ON+ROAD
ask when they are getting stock in...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-16-2012, 10:26 AM   #392
pete68's Avatar
Originally Posted by hanulec View Post
call these guys-
thanks
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 01-12-2013, 06:57 PM   #393
Just finished building my HMX and will be picking up a pair of the new gear diffs ready for testing the following weekend UK weather permitting of course.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 01-15-2013, 06:40 AM   #394
Ok just built two of the new design gear diffs and put them on the scales to see what they compare like to the ball diff.
Spool 10g
Gear diff dry 18g
Gear diff oil filled 19g
ball diff 23g
Old 01-15-2013, 07:47 AM   #395
Spool 10g
Gear diff dry 18g
ball diff 23g
Now you're talking!! So they are really light. Have you compared them with a SpecR or Tamiya unit?
I already have a HMX with two Tamiya diffs but I think I'll buy a second one with the new gear diffs and race my older one in vintage
Please let us know how good they are on the track....
stidanielt09 is offline   Reply With Quote
Old 01-15-2013, 08:14 AM   #396
Jimmy Morris's Avatar
They are lighter then a spec-r diff. I think by about 6 grams iirc.
Jimmy Morris is offline   Reply With Quote
Old 01-17-2013, 07:56 PM   #397
One advantage of the gear diff is you can fit the pulley to the side instead of the normal position which makes doing the mod to the spur gear holder / layshaft so you can run standard pinions an easy job.
Shame its snowing in the UK so i wont get to track test it for a while.
http://www.youtube.com/watch?v=nX7by_Unt0Q
Old 01-18-2013, 03:54 AM   #398
Default hmx
Hi Weekend Racer,
How have you modified the lay shaft?
Stelios
Monty Mole is offline   Reply With Quote
Old 02-19-2013, 10:49 AM   #399
Trader Rating: 14 (100%+)
Default Gear diffs
Hi fellow Corally drivers, Iam a Corally fan and have been for some years , first car is the assassin single belt right through to the hmx. Love the build quality and ease to work on and durability.finally got the new gear diffs but find they are very notchy is there a remedy cheers steven
koolys is offline   Reply With Quote
Old 02-21-2013, 05:05 AM   #400
After the first run mine freed up alot and was very smooth. You might just have some burs on the metal spur gears.
Old 02-21-2013, 05:27 AM   #401
niznai's Avatar
Yeah, I got two gear diffs too and mine are a bit notchy. Just a little bit, but definitely there. I'll probably run them in on the bench with some sticky grease and then clean and fill up with oil.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-23-2013, 07:25 PM   #402
Default Sgx tips
Thnx guys when I get home from work I'll put the diff in the car and run it on the track cheers steven
Old 03-18-2013, 02:56 PM   #403
Rick Pfeilstick's Avatar
Default How about brad Johnson's nat set up?
Can you post your set up from last weeks nats?
THREE NINE, JESSPEED, MCFACTORY. MMR.
Rick Pfeilstick is offline   Reply With Quote
Old 05-07-2013, 11:47 AM   #404
Corally USA's Avatar
We've found the diffs tend to be a bit notchy at first. We like to build them with the red Corally lube, run them once, and then rebuild them. They should be smooth after that.
There's also some new internal gears coming out for the diff that are a bit stronger for guys running mod.
CorallyUSA.com - SpecializedRC.com - SXT - Superiorhobbies.com
Corally USA is offline   Reply With Quote
Old 05-14-2013, 11:16 AM   #405
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Anyone looking in getting the new hmx should not think twice. I'm about finished building the new (carpet kit) by far best build I've had in years with Corally. Don't hesitate call CorallyUSA or superior hobbies and get your hands on this kit. Their is going to be a build write up soon to be up on the CorallyUSA.com website so keep a look out on that !
Roberto Falcon is offline   Reply With Quote
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 06:59 AM
