Old 11-22-2012, 06:14 AM   #376
Corally do produce some great stuff but it just seems to take them longer than anyone else to get it out there in the market place.
Still not built my HMX yet as i have been to busy with other things and i tend not to race outdoors in the winter here in the UK as im getting to old and grumpy to be standing around all day getting cold and wet. Roll on the spring time lol.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 11-22-2012, 04:16 PM   #377
Rick Pfeilstick's Avatar
looking to run spec r front drive shafts for a tamiya 417. any body know what mods i need to do?
- THREE NINE-JESSPEED- DURANGO-FANTOM-XRAY-CRC-
Rick Pfeilstick is offline   Reply With Quote
Old 11-22-2012, 04:19 PM   #378
transplantlife's Avatar
Trader Rating: 43 (98%+)
Rick you will need to use a tamiya 416 spool with 417 dcj and do a little modding. Get in contact with brad johnson on here he has this on his car.
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 11-25-2012, 06:53 AM   #379
Default On and Off power oversteer
Hi Guys,
What setup changes do i need to cure the above understeer problem, the car is setup as per manual?
Stel
Monty Mole is offline   Reply With Quote
Old 11-25-2012, 05:22 PM   #380
bjames's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Monty Mole View Post
Hi Guys,
Stel
You could try the short camber link option. It seems to have a lot more steering if the traction is available. I tried it this past weekend but it was a new layout on virgin carpet and the traction just wasn't high enough. What kind of surface are you running on? Are you using gear diffs, spool...etc?
-Brian James-
bjames is offline   Reply With Quote
Old 11-26-2012, 02:59 AM   #381
Default Corally HMX setup
Hi BJames,
I currently run on carpet which is medium to high grip, at the moment using spool and ball diff, sorex 28jb tyres.
My current setup is:
Alloy shock towers, 45wt oil front/35wt rear,droop 1 front/ 5 rear.
No anti roll bars, 17lb springs front and rear. ride height 5mm front/ 5.5 rear.
Thanks for PM could you send me your setup please?
Stel
Old 12-02-2012, 08:09 PM   #382
Due for release 12-12-12
Corally.com
I Hope Santa is running mod 'cos it is a long trip to my place.
Peter
Pedro 51 is offline   Reply With Quote
Old 12-03-2012, 01:12 PM   #383
great explanation.
sahil is offline   Reply With Quote
Old 12-03-2012, 02:26 PM   #384
Corally.com
Peter
Corally gear diff or what will be release
Lizardboy76 is offline   Reply With Quote
Old 12-03-2012, 02:29 PM   #385
theatriks's Avatar
Is the site corally.com down?
theatriks is offline   Reply With Quote
Old 12-04-2012, 04:12 AM   #386
Default Corally HMX
Just seen the CAD drawing of the Gear Diff on Corally.com site, seems expensive and diiferent.
Old 12-04-2012, 05:10 AM   #387
Robert_K's Avatar
New Geardiff. Nice idea, but heavy?
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 12-04-2012, 07:50 AM   #388
C van der Hagen's Avatar
Regards Robert
Not heavier then a regular gear diff.
C van der Hagen is offline   Reply With Quote
Old 12-15-2012, 08:02 PM   #389
pete68's Avatar
where in the us or canada corally is available !!!
Yokomo BD7-15/YZ2 ORCA/SMC/FUTABA
pete68 is offline   Reply With Quote
Old 12-16-2012, 06:14 AM   #390
niznai's Avatar
I was thinking of designing the same sort of gear diff for my old Kawada chassis (narrower bulkheads than anything else on the market ever). If Corally pulls it off, that would be enough reason for me to buy their car.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 07:59 AM
SEO by vBSEO 3.5.0
