Old 07-10-2012, 08:05 PM   #316
Jimmy Morris's Avatar
Originally Posted by transplantlife View Post
Guys looking for lowpro 07 shock toweers F/R part # 79740 if you have any..
try giving superior hobbies a call. 407-834-9299
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 07-10-2012, 08:12 PM   #317
transplantlife's Avatar
Trader Rating: 43 (98%+)
I spoke with robbie today and nadda ive found a set already.
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 07-10-2012, 08:16 PM   #318
Please share your set-ups for the HMX for both carpet & tarmac
front
45 wt ae oil
tamiya white springs
tamiya 3-hole pistons
.5 blocks dots out
silver sway bar
inner hole on 07 lowered tower
outer most hole on arm
4mm droop measured under c hub
4* caster
long wheel base
spec r gear diff with cleaning clay
-1.5 camber
rear
45 wt ae oil
tamiya yellow springs
inner most hole on lowered 07 tower
inner most hole on arm
4mm droop measured under set screw
2.0 FR block dots out
0 RR block
silver sway bar
long wheel base
spec r gear diff 1000 cst
ball stud in outer hole on rear hub
-1.5 camber
Old 07-10-2012, 08:50 PM   #319
Jimbo thanks for taking the time to list your set-up!
Old 07-11-2012, 04:49 AM   #320
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Originally Posted by Lizardboy76 View Post
My Corally HMX manual said 2.5mm diff ball, was that a mistake
I think 2.5 is correct, but I'd have to measure when I get the chance. When I have ran ceramic diff balls, I've needed to leave the diff rings a little rougher as the ceramics seem to slip a little more on the rings if they are too polished with fine sand paper.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 07-11-2012, 07:19 AM   #321
My mistake. Sorry
HMX uses 2.5mm diff ball
I use Muchmore diff grease with 4 Diff Washers.
2.5mm corally diff ball
Does anyone use 2.4 chassi on asphalt
The hmx with 2.0 chassi twists alot
Br,
Rodrigo
Rodasfer is offline   Reply With Quote
Old 07-11-2012, 07:25 AM   #322
MAD916's Avatar
Think we may have 07 parts in stock at www.timeonehobbies.com. But am away from shop today. Take look we had pretty good collection of phi and Rex stuff
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 07-11-2012, 11:30 AM   #323
do any other sway bars work on this car?
Old 07-12-2012, 09:12 AM   #324
Originally Posted by spacendeman View Post
http://www.arroyoc.com/index.cfm?fus...=Gear&Plot=mid
Google, and than gearchart rc .. and then the upper link. so now you can see what pinion and spur size you need.
As I see it FDR3.5 can be made with 66/32. 32T Being the biggest Corally pinion. FDR would be 3.526875 that way. Can it be meshed the proper way on the HMX? If so I am going that way.
Haven't you raced FDR3.5 yet?
68/33 Is not an option imo because Corally has no long boss 33T pinion.
All of that knowing that I want to use 48Dp.
10SL racing has come to an end for you? I see you race HMX at the Dutch nationals as of this year.
I am still interested in pro10 racing but the number of drivers at the Dutch nationals is decreasing every year.
RC LeMans might be an option.
Kensei is offline   Reply With Quote
Old 07-12-2012, 10:41 AM   #325
wuzi's Avatar
Tamiya 3 holes are to smal for corally shocks
wuzi is offline   Reply With Quote
Old 07-12-2012, 10:43 AM   #326
spacendeman's Avatar
Send a message via MSN to spacendeman
Hi,
FDR 3.52 also an option so you then can get those gears.. I haven't tried the normal pionions yet , so maybe someone can give an awnser to that.
Still have my 10sl. But this year I'm driving HMX. Maybe next year also some rounds with my 10SL again. Maybe indoor ...
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 07-16-2012, 03:29 AM   #327
Anyone know the part # for the 510mm drive belt? or what other drive belt will work when using tamiya ta05 gear diffs.Thanks
Old 07-16-2012, 10:41 AM   #328
BJohnson's Avatar
510mm rear belt part # 79135. Hope this helps.
BJohnson is offline   Reply With Quote
Old 07-22-2012, 07:57 AM   #329
theatriks's Avatar
does anybody know who sells these in the usa or preferreably canada?
theatriks is offline   Reply With Quote
Old 07-22-2012, 10:33 AM   #330
try giving superior hobbies is corally usa a call. 407-834-9299 ask for tj they dont have any kits in stock at the moment there waiting on the v2 kits coming
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 06:59 AM
