Old 07-05-2012, 07:06 AM   #301
Holmenkollen's Avatar
Originally Posted by Uziman View Post
What oil are you guys using in your gear diff front and rear?
Im using Losi 90 W in rear and 500k in front.
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 07-05-2012, 10:41 AM   #302
Default HMX FDR
FDR HMX with 48DP
4.5 with 78 and 29
The chart in the manual ends at FDR 4.17 with 78 and 32.
How do I make 4.0 and 3.5? These are used in stockracing at the Dutch Nationals (and other events also).
Kensei is offline   Reply With Quote
Old 07-05-2012, 11:45 AM   #303
spacendeman's Avatar
Send a message via MSN to spacendeman
Originally Posted by Kensei View Post
FDR HMX with 48DP
4.5 with 78 and 29
http://www.arroyoc.com/index.cfm?fus...=Gear&Plot=mid
Google, and than gearchart rc .. and then the upper link. so now you can see what pinion and spur size you need.
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 07-05-2012, 12:58 PM   #304
Thanks Tim.
I already knew the pinion size I needed.
That wasn't the problem.
The problem is that I don't see those sizes on the Corally website.
So which ones to use knowing that the largest one on the Corally website is 32T?
And knowing that on the Corally website there are no spurs smaller than 78T.
Old 07-05-2012, 01:02 PM   #305
My car.
http://rcblogg.files.wordpress.com/2...705_204143.jpg
Old 07-05-2012, 01:52 PM   #306
Thanks Tim.
That is true. I use Kawada spurs. I order them by rcmart.com Those spurgears should work fine too.
Currently:
Old 07-05-2012, 02:19 PM   #307
Are these the ones you mean?
http://www.rcmart.com/kawada-Store-m...page=3&sort=1a
So you only can vary the FDR with the spur? (as to an FDR that would need a pinion > 32T)
Not with the pinion because the HMX needs long boss?
A bit of a hassle, isn't it? Or is the spur on the HMX interchangeable in an easy and quick manner?
Isn't there an alternative for the Corally long boss pinions? (especially when needed >32T)
If so which ones?
Old 07-05-2012, 06:13 PM   #308
Jimmy Morris's Avatar
I've been wanting to try the 500k. How do you like it? I have cleaning clay in my front diff and associated 1000 cst in the back.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 07-06-2012, 12:26 AM   #309
Its good for tighter tracks. On tracks with long fast flowing corners I think cleaning gum would be a better choice.
Old 07-06-2012, 07:57 PM   #310
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
I have had better luck with a spool over using the putty. It seems the putty breaks down, or just gets crammed into the voids after a couple of runs.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 07-10-2012, 05:08 PM   #311
transplantlife's Avatar
Trader Rating: 43 (98%+)
Guys looking for lowpro 07 shock toweers F/R part # 79740 if you have any..
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 07-10-2012, 05:09 PM   #312
Please share your set-ups for the HMX for both carpet & tarmac
Old 07-10-2012, 05:25 PM   #313
I built my diff with acer racing ceramic 2.5mm size diff ball and my diff seem's very tight I tried to adjust it but it still tight, any tip's on how to build one correctly? Also any team drivers racing at 2012 world champ's?
Lizardboy76 is offline   Reply With Quote
Old 07-10-2012, 08:10 PM   #314
Hi Lizardboy76
Corally HMX uses 3.5mm
br
Rodrigo
Rodasfer is offline   Reply With Quote
Old 07-10-2012, 08:43 PM   #315
Originally Posted by Rodasfer View Post
Hi Lizardboy76
br
Rodrigo
My Corally HMX manual said 2.5mm diff ball, was that a mistake
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 07:59 AM
SEO by vBSEO 3.5.0
