Old 07-02-2012, 01:52 PM   #286
Jimmy Morris's Avatar
Originally Posted by spacendeman View Post
Looks very nice! You just put the bearing holders of the diff otherwise? so with the round of where de bearing is in to the inside? Looks nice the hmx! what are you running?
Yeah the bearing is on the inside of the bulkhead. Works great and requires no additional parts other then the belt. No big deal. Mostly I run 17.5 and 13.5 on asphalt. Occasionally carpet. The car works very well on both.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 07-02-2012, 01:54 PM   #287
spacendeman's Avatar
Send a message via MSN to spacendeman
Ok nice! Maybe going to try it. But for running a spool in front you think a tamiya spool would also fit?
Do you maybe have more pictures? :-)
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 07-02-2012, 02:27 PM   #288
I cant say as I haven't tried a tamiya spool. I was going to just glue up a spec r gear diff for a spool. I can take more detailed pics once I get home.
Old 07-02-2012, 03:50 PM   #289
BJohnson's Avatar
I have been using the Tamiya 37 tooth front gear on a Corally spool. That way I can drop the Spec-R gear diff in and out of the front without having to change any of the belts.
BJohnson is offline   Reply With Quote
Old 07-02-2012, 03:52 PM   #290
BJohnson's Avatar
The Tamiya 37 tooth gear is a $6-$8 part instead of ruining a Spec-R gear diff. Just a thought.
Old 07-02-2012, 06:20 PM   #291
It was Robbie's idea I swear lol
Old 07-02-2012, 08:06 PM   #292
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
And don't be worried, but you'll have to open up the mounting holes a little, at least I had to.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 07-02-2012, 09:43 PM   #293
Thanks for the ibfo guys! Any building tips also?
Currently:
Old 07-03-2012, 01:32 AM   #294
transplantlife's Avatar
Trader Rating: 43 (98%+)
use ta05 spec r gear diffs
tamiya 3 hole pistons
drive it like you stole it
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 07-03-2012, 04:35 AM   #295
Haha thanks for the tips! ;-)
Currently:
Old 07-03-2012, 03:26 PM   #296
HMX on the way! YAY
Old 07-03-2012, 09:33 PM   #297
Nice to hear! When do you think the kit will be there? Mine shall arrive today or tomorrow.
Currently:
Old 07-04-2012, 01:15 AM   #298
I jus orderd the hmx today we a holiday here tomorrow 4th of July so im thinking i should have the kit within four business days. I will post pics once i get the kit.
Old 07-04-2012, 04:50 AM   #299
Great news! Have a happy 4th of july! We need to work here :-p
Currently:
Old 07-05-2012, 05:37 AM   #300
Uziman's Avatar
What oil are you guys using in your gear diff front and rear?
Corally RDXΦ'09 ★ Airtronics/Spektrum ★ Tekin ★ Fantom
★ www.aerccc.org.au ★
Uziman is offline   Reply With Quote
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 06:59 AM
