Old 04-04-2012, 01:24 AM   #226
wingman2's Avatar
Originally Posted by stidanielt09 View Post
Hi Chris,
the spool we can see in this HMX is a Delrin 36 Teeth spool, which is part number 79157 and the shock towers we see seems to be Phi09 towers, part number 79742 and 79743.
I'm using Phi07 lowered shock towers on my HMX and it works flawlessly.Those Phi07 towers are part number 79740. Some people are complaining about insuficient shock lenght and those shock towers could solve most of these issues.
But you can also keep in mind that Corally has a new model of CF Shock Towers made specifically for the HMX. Part number 79761 will be for the front and 79762 for the rear of the car.
I hope this would answer to all your questions.
Hi mate, thanks very much! I understand that the Version 2 kit will be released soon that actually has those parts as standard. I had a go with an old TC for the first time last weekend and really enjoyed it (normally run 12th and GT10) so will be looking at getting one of the V2 HMX's once they are released. Thanks once again
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 04-04-2012, 01:59 AM   #227
spacendeman's Avatar
Send a message via MSN to spacendeman
Hi,
The information is correct about the parts. I drive the hmx with just the stock spool. I hope too that the second serie hmx is comming soon! I run the hmx with the optional hmx carbon shocktowers but I had to make them a little longer. I did that with some lexan I had left of cutting body's. Works also and you can drive with the anti rollbars. I thought that the shocktowers you showed on the picture are direct fit also with the roll bars but I didn't had them.
Greetings,
Tim
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 04-04-2012, 06:09 AM   #228
Jimmy Morris's Avatar
Rather than using lexan to keep the sway bar bearings in place, I used the kit red shock towers with the "wings" cut off, and put them in front of the lowered phi 07 carbon towers with an extra long screw. So the carbon tower is sandwiched between the bulkhead and the cut shock tower. It works rather well and keeps the bearings perfectly seated.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 04-05-2012, 07:05 PM   #229
Hey Jimbo,
I would like to see pictures of your HMX with those cut shock towers. Would it be possible to post pictures of it?
Thanks in advance.
Daniel
stidanielt09 is offline   Reply With Quote
Old 04-06-2012, 06:34 AM   #230
heres the only one I have right now
Old 04-06-2012, 10:37 AM   #231
Nice! Thank you very much for the picture but I'm not sure that I wanna ''sacifice'' those beautiful alu shock towers, tought! Lol!
So you too are using a Phi07 shock tower? I was able to make them hold the sway bar bearings with no aditional lexan or cut-off shock towers.
Anyway, I would like to know which gear diff are you using? Is it a Spec-R TA05 unit? I'm using the Tamiya ones and can't make them fit by switching the bearing olders from left to right like you did. I had to shim the bearing instead.
Old 04-06-2012, 01:01 PM   #232
Yeah they are lowered 07 towers. I originally had them on without the aluminum part but they seemed to get a little sloppy after a few runs. And yeah, its a spec r ta05 diff with the bearing holders flipped around.
Old 04-07-2012, 07:32 AM   #233
It looks very nice! maybe an idea to do that too.
Do you also have some close pictures of that geardiff with the bearingholders?
Currently:
Old 04-08-2012, 09:00 AM   #234
Krijn's Avatar
Default HMX
well my 1st series HMX arrived wednesday and has now been assembled , my 2nd series is in Toronto and asfar as i know has the geardiff and new alu parts but we will see.
i understood that Corally will be releasing a 17.5 turn brushless motor soon
Thanks Brad for shipping it on short notice (you did however confuze canada post, they where convinced it would take 4 weeks to be deliverd )
Krijn
Krijn is offline   Reply With Quote
Old 04-08-2012, 09:06 AM   #235
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
HAHAHAHA
DriftSesh is offline   Reply With Quote
Old 04-11-2012, 02:41 PM   #236
Krijn's Avatar
Default Corally HMX
well the 2nd one has arrived and yes.. new shocktowers front and rear, the front ones seem a little shorter while the rear ones are actually taller looking (no i didnt put the wrong one at the rear) the rear shocktowers have changed angles and what looks like 2 more ballstud mounting holes, these are however not threaded, overall the ballstud is 52mm from the chassis compared to 55 mm in the old shocktower a lower mount option on the new shocktower can be at 47mm.
sadly no geardiff yet.
pictures to follow later if requested.
Krijn
Old 04-11-2012, 05:15 PM   #237
wingman2's Avatar
Krijn
Yep, show us some pics!
What gear diff will you be putting in the V2 car??
Old 04-11-2012, 08:04 PM   #238
Krijn's Avatar
Default hmx v2
ok pics as requested, done in a hurry, empyt battery in camera, lousy camera , and i'm not a photographer...
oopsy, sadly i havent made the required number of posts sofar so it will not let me post links to the pictures
Krijn
Old 04-12-2012, 02:15 AM   #239
wingman2's Avatar
Krijn
No worries mate. I am going to try out a TC for the first time this weekend. Its an older Corally chassis and if I like it, then an order for a V2 HMX will take place! Cheers, Chris
Old 04-12-2012, 02:17 AM   #240
Hey,
No problems for the pictures , those will come when you have more posts
@ wingman2 , are you going to try the phi'09? I hope you like it. Let us know the experiance!
I drive the HMX a mounth now outdoor and I must say the car is very stable! and very easy to drive
Currently:
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 07:59 AM
SEO by vBSEO 3.5.0
