Old 01-16-2012, 10:01 PM   #196
[[john]]'s Avatar
Trader Rating: 24 (100%+)
Hi Guys, where can I buy this online? Also, what gear diff; if any fits?
I haven't got a chance to look through this thread now, but will when I am able too.
Thanks in advance
[[john]] is offline   Reply With Quote
Old 01-16-2012, 11:01 PM   #197
Holmenkollen's Avatar
Originally Posted by vwvrt View Post
Im going to order the belt tommorow , i was looking at it i suppose you could change either the front or rear belt, i just randomly chose the front one , if there is any specific reason that you changed the rear belt instead, please tell me. To flip the layshaft and gears you have to cut a slot in the chassis for the spur gear closer to the motor mount , then just flip the layshaft over turn the internal shaft around so the side with the spacer is on the motor side, then just re shim it so neither side rubs. with the 37 t pulleys the internal gear ratio becomes 1.76:1. Ill try and put pic up . can anyone tell me why they built this car with an internal ratio of 1.71 when most other manufactures try to get as close as possible to 2.0
Donīt the spur gear hit the motor screw? I like the idea of the spur gear in the middle instead but that needs a little bit more fiddling.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 01-17-2012, 04:13 AM   #198
Originally Posted by FunkyDunky View Post
Nope :-)
Well, let's wait some more than.
Kensei is offline   Reply With Quote
Old 01-17-2012, 10:50 AM   #199
no, if you shim it correctly it does not rub the motor screw, i have about 2.5mm gap on mine.
vwvrt is offline   Reply With Quote
Old 01-17-2012, 07:36 PM   #200
Hey guys,
see post #149.
Pictures of my HMX with two Tamiya Ta05 Gear diffs on it.
Everything fits perfectly, sway bars mount too with little dremel work. You will have to shim the diff a little but it does fit very well as my pictures will show you.
I used Corally 18Teeth Center Pulley, instead of 21Teeth from the box, both gear diffs has 37Teeth. In the front, I used a longer Corally 510mm belt instead of the stock 507mm one. By the way, that longer front belt moves the lay shaft little further to the back which will give you more space for bigger teeth count pinions. I used Tamiya TRF 415 rear belt, two different parts number are available but same length. Also, Spec-R are making longer pinions that fits amazingly good, but I was also able to fit RobinsonRacing ones with no problems at all.
I am a Corally fan since the RDX and I have owned many RDX, Phi'07and Phi'09 but my HMX is by far the best car I ever had, I love it.
It is my fastest car so far, it is easy to drive and extremely consistent. I raced it a week ago and I did my best ever results.
I'm racing on carpet, blinky mode is the only touring car class we have at my local track.
stidanielt09 is offline   Reply With Quote
Old 01-20-2012, 12:23 AM   #201
Originally Posted by stidanielt09 View Post
Hey guys,
see post #149.
No problems with the driveshafts touching the outdrives when you compress the damper? With the Spec-R TA05 gear diffs you cut the outdrives 3 mm or use shorter Tamiya driveshafts.
Old 01-20-2012, 03:52 PM   #202
yes the original driveshafts are to long , ive got tamiya 44mm shafts in mine , i think you could also use the shorter axles from the front of the hmx. does anyone stock the spares for this im looking for a set of anti roll bars. I used the 189 rear belt instead of the 510 front because as somone has already said i planned on using smaller pinions , if i was using larger pinions higher ratio i would have got the longer front belt.
Old 01-21-2012, 04:04 AM   #203
What spring are you guys using , my kit came with the 22 pound 5.25 turns which I thought would be to hard . The manual says use 17 all round . I had a set off rayspeed 17lbs white fronts and 14 lbs blue rears . But the rear is a bit to soft
Old 01-21-2012, 06:44 AM   #204
Send a message via ICQ to #iZzy Send a message via MSN to #iZzy Send a message via Yahoo to #iZzy
All of you guys should measuring your rear toe-in manual way - put your Corallys upended and measure your toe-in with an camber gauge, should be something around 4°
Turn your Corally's around and take a look on the chassis screws where the rear toe-in blocks are mounted. You will see that the RR blocks are more outer mounted then the RF Blocks!
really weird, that the corally team drivers realized that issue.
I've made a small picture now four you to show that issue:
Team Magic Europe - HRC-Distribution - GM-Racing - LMI - MR33 - Tonisport
#iZzy is offline   Reply With Quote
Old 01-21-2012, 06:56 AM   #205
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Has anyone tried an Mi4 gear diff in the HMX? It's a 36t pulley.
brians11 is offline   Reply With Quote
Old 01-21-2012, 12:33 PM   #206
I'm using shorter Corally part number 79182 CVB Bones because the supplied ones are little too long with Tamiya gear diffs. With shorter ones from older RDX/Phi'07 models at all four corners, everything fits perfectly. Not sure if it would fit with TRF417 gear diff because the diff itself is little longer. And I haven't tried any SpecR diff either, Tamiya diff are so inexpensive......why would I pay more for a SpecR one?
Also, for all of you having issues with your damper being too short for droop adjustement, you could use Corally part number 79222, which are damper shaft from older ones and they are few millimeters longer.
But newer pistons are thinner so you would have to shim them a little.
Old 01-21-2012, 11:47 PM   #207
spacendeman's Avatar
Send a message via MSN to spacendeman
No not yet but maybe that is an option. but I don't know anyone who has an schumacher chassis at my local club
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 01-25-2012, 08:14 AM   #208
Great!
BTW, new graphite shock towers will be released in middle of Feb.
Old 01-28-2012, 02:06 PM   #209
Hi, for anyone that is interested I am selling my brand new HMX via ebay at a very discounted price
http://www.ebay.co.uk/itm/BRAND-NEW-...#ht_720wt_1187
:-D
Hi. Some time has passed. What about the sell?
Any luck so far?
If not, than the price maybe is a bit steep?
Best of luck.
Old 02-05-2012, 01:55 AM   #210
Paul Sweeney's Avatar
Location: Somewhere Back Stroking Under The Verrazano Bridge
Send a message via AIM to Paul Sweeney
Can Anyone Tell me if HMX Shock O-Rings will fit The Phi 08 Shocks
X-Ray NT1 / Mugen MRX4-R / Corally RDX PHI.08 / I.R.S. Shockwave WGT/ Tamiya F104 / Mugen MBX-5 / Jammin X1CRT / Novarossi / Futaba Fasst 2.4ghz / Mike L. Designs
*****************Brooklyn Hobbies********************
************Gentlemen: Start Your Engines *************
Paul Sweeney is offline   Reply With Quote
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 06:59 AM
