Old 01-06-2012, 10:39 AM   #166
speedybill's Avatar
Trader Rating: 73 (100%+)
Wink
Originally Posted by Kensei View Post
I don't want the threaded boydposts.
What part number to use body posts with holes in 'em and "dishes" and clips?
When does the car come with geardiff?
for body posts try "HPI 6507"
Thankx,Bill
ROAR member #5-120259
www.speedybillsrc.com
www.ovrccc.com
Sweep Racing Tires
speedybill is offline   Reply With Quote
Old 01-06-2012, 10:55 AM   #167
Originally Posted by FunkyDunky View Post
Hi, for anyone that is interested I am selling my brand new HMX via ebay at a very discounted price
http://www.ebay.co.uk/itm/BRAND-NEW-...#ht_720wt_1187
:-D
You have a PM.
Kensei is offline   Reply With Quote
Old 01-11-2012, 05:39 PM   #168
What stabilizer can I use the RDX, Also is there a Titanium screw set avail.
Lizardboy76 is offline   Reply With Quote
Old 01-11-2012, 11:47 PM   #169
spacendeman's Avatar
Send a message via MSN to spacendeman
You realy mean the rdx? there is also a phi'09 threat here at the rctech forum.
For the hmx is the system different. allthough I think the stabelizers are the same. but an other system.
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 01-12-2012, 07:07 AM   #170
Anyone used the HMX outdoors on tarmac yet and if so how did it compare to the Phi 09 ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 01-12-2012, 07:14 AM   #171
I haven't used it even on carpet .. so I can't tell you something about the car.
Do you maybe have some suggestions for running on carpet? high grip carpet and smal track. I have tamiya white springs...
Currently:
Old 01-12-2012, 11:56 AM   #172
Got my hmx finished today , I will be running it at my local club night tommorow and then at rugracers all day sunday.really pleased with it the body mounts take a bit of getting used to ,but its a very well made car the plastics feel very strong alloy parts are well machined , it feels like it has a lot of flex. I had a quick test run on tuesday before i had fully set it up and it felt nice to drive loads of grip.
vwvrt is offline   Reply With Quote
Old 01-13-2012, 12:02 PM   #173
Originally Posted by Holmenkollen View Post
Yes. I canīt get enough steering throw with Corally parts, the steering knuckles hit the swaybar ball cup. You can dremel the knuckles and ball cup but I donīt think you can get same amount of steering throw as with Tamiya parts. If you are using Corally parts use the 4 degree alu caster block, itīs thinner than the 3 degree plastic = more throw.
I use Spec-R TA05 37t geardiffs. You have to use a 189 mm rear belt with this setup and a 37t front pulley if youīre using a spool. Otherwise you get some overdrive....
If youīre using the geardiffs with the Corally suspension you have to cut off 3mm on the geardiff outdrives and drill the hole a bit to avoid binding. Tamiya driveshafts are shorter so this is not a problem with Tamiya suspension.
You also have to trim one of the geardiff sides otherwise the swaybar alu. mount will interfere. Itīs a bit of work to make it all fit nicely but you canīt compete in modified nowadays with a ball diff....
Corally is coming out with a gear diff soon.
- what partnumber is the 4 degree alu caster block?
- what partnumber is the 189 mm rear belt?
- what partnumber is the 37t front pulley?
- so the DTR changes? In to what value?
- drill the hole a bit? That means one or both holes of the outdrives of the geardiff?
- what do you actualy have to trim on the rear geardiff side?
- cut off 3mm. So that is on both the outdrives of the geardiff? So 6mm in total?
Old 01-13-2012, 02:56 PM   #174
If you look at Brad's pics, you can see some of the sway bar and steering mods better. Corally HMX
Those C-Hubs are from the Assasin, Try number's 79284 and 79285 and the steering blocks are Phi 09's
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 01-13-2012, 05:56 PM   #175
I ran the hmx tonight , it was very good, im faster with this than with my 417. the hmx is very consistant and easy to drive , pleased i did the swap.
Old 01-14-2012, 03:17 AM   #176
Originally Posted by BJohnson View Post
Here are some pics of my HMX with the 07 lowered CF towers.
C-Hubs number's 79284 and 79285 4 degrees caster, aluminium?
And the steering blocks are Phi 09's?
Are these aluminium?
What part numbers?
I see several: 79278, 79278A, 79279A, 79279, 79631/79632.
Which ones to use and for what reason?
Any other modifications I should consider?
For instance longer balljoints for the shocks.
I heard some complaints about not being able to set the droop as wanted. Shock too short. Longer Corally balljoints available? If so, what partnumber?
I want 2.5 degree toe-in at the rear, not 3 degree. How do I do that?
Do these fit for HMX or just for 1/12th. In other words, are these long enough?
#75995 12SL / X - 10SL / X - F1 WC Bodyposts -
Including body pivots and clips (4 pcs) - OPTION
Or go for these like speedybill suggested: for body posts try "HPI 6507"
@BJohnson: which bodyposts do you use?
Old 01-14-2012, 09:21 AM   #177
speedybill's Avatar
Wink
I am a Total Corally freak
Been running the older RDX for over 6yrs
Just went to a Losi Type "R"
Been waiting on the release of the "HMX"
But I am rather disappointed of all the 'upgrades' needed to be competitive
are these upgrades absoutely needed
or could ya run it as it is?
Thankx, Bill
www.ovrccc.com
Sweep Racing Tires
Old 01-14-2012, 10:38 AM   #178
Thankx, Bill
VERY GOOD QUESTION........
I hope to get away with the following modifications:
- Corally geardiff (still to come..... when???) and oil to go with it
- swaybars. Not in the kit. IMO a bad thing!
- other bodyposts (always hated the "screwing" leaving me with pain in my fingertips)
- softer spring in the back (I have the Corally springset from my days with the RDX so no extra out of pocket expense there)
- less rear toe in. I prefer 2.5 degrees
Other needed setup changes and fine tuning must be doable within the standard kit parameters.
Old 01-14-2012, 10:45 AM   #179
You can always adjust the rear toe in with the same suspensionblock you use at your rdx.
The car comes with 2,5 toe in rear.
Geardiff don't know when it comes... but do you realy need it in the stock class?
Other bodyposts.. That is a thing for you. That's what you prefer. I always use the corally posts. also on my 10SL.
If you realy need al the hopups that is a thing that I don't know because U haven't driven the car yet.
What about the springs I can't awnser that because I haven't driven. Some people say that it is good out of the box. See early posts here at this topic.
Currently:
Old 01-14-2012, 11:00 AM   #180
- as to rear toe in: in the manual on page 7 it says 3 degrees toe in. On page 8 of the manual you can see that 2 degree en 0.5 degree wishbone mounts are used. So obviously I thought that that would be 2.5 degrees toe in. I asked Joeri Bal from Corally Holland in Dordrecht and he said it was 3 degrees. I stilll don't understand, but hey who the heck am I...?
- as to geardiff. For me it is more of a user friendly kind of thing. Never been a fan of balldiffs
- as to springs. As I know it almost everybody, who races on tarmac/asphalt, uses a slightly softer spring in the back. I did so with my RDX and I am going to do so with the HMX
- swaybars: I always used them. You can go softer in shockoil and springs without losing too much corner speed
- as to bodyposts: Corally has the ones I am looking for. They use them on there 1/12th car. So I don't know if they are long enough for TC. Corally Holland is going to inform me on that. If they are too short I may be can use HPI. Would like to know which ones BJohnson is using
So as to hop ups. It doesn't have to be that kind of a drama.
As said, I try to limit it to the geardiff and oil that goes with it, other bodyposts, softer springs in the rear and sway bars.
At first I will try a setup that is in the neighbourhood of what I used with the RDX. From there I can fine tune.
Corally RDX Phi 09 Pro Models Electric On-Road 771 01-22-2016 07:59 AM
SEO by vBSEO 3.5.0
