Old 11-12-2004, 02:49 PM   #1
Default Using different rollout for different tracks?
My question is this. I race on a tight 56x32 carpet track, brand new ozite, about a month old. Each week the track changes. I've been trying to figure out what should I be using for rollout. I've driving a xxx-s, monster stock, my foams are 58-60 mm depending on what set I use. I've been any where from a .94 to .87 and everyone seems to have more pull through the corners. Straightaway speed I can hang, but corner speed I just don't seem to have it.
I feel I've got a pretty good handle on the set up making gains in that area. Not sure what I should be at for rollout. I'm running 767 brushes, with red/red springs.
Any ideas on what is a good start I'd appreciate it.
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 11-12-2004, 03:08 PM   #2
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
That could also be very well attributed to car setup...
If the motor is bogging down in the corners that much then the car's drivetrain is bound up or the suspension isn't working idealy for track conditions.
USVTA Member #211
Yokomo BD7 (Mod TC), Corally Phi '07 (VTA)
Support Formula SAE - get kids into engineering!
Brian McGreevy is offline   Reply With Quote
Old 11-12-2004, 03:52 PM   #3
Merciless's Avatar
Send a message via ICQ to Merciless
Roll out for a monster will be in the region of 26mm +/- 1mm depending on track size (carpet indoor).
The problem your stating sounds more like a suspension issue though, i would usually say loseing alot of ground though the infield due to bogging down would be because your scrubbing to much speed in the corners.
No dought your car is very stable and quiet easy to drive, just not as quick as the front runners through the infield ??
Try harder springs or possibly a roll center alteration to reduce roll and see how that feels
Merciless is offline   Reply With Quote
Old 11-13-2004, 03:23 PM   #4
Try different pinion, and measure your laptime. Sometimes smaller pinion can give you faster acceleration out of corner and better lap time.
raceblast is offline   Reply With Quote
Old 11-13-2004, 03:31 PM   #5
rcinsight's Avatar
The rule of thumb I was taught by veterans and sponsored drivers alike was to gear your car so It does not wind out by the end of the straight away and not too under powered at the same point.
If your car sound like it has more rpms to use then it may need a smaller pinion.
Smaller tracks, use smaller pinions to get up and get 'er done. Longer tracks could use larger pinions to reach the higher speeds.
rcinsight is offline   Reply With Quote
Help rollout! Ashley Cobb Electric On-Road 14 04-20-2007 05:00 PM
rollout 3808larry Electric On-Road 3 12-12-2006 05:28 PM
rollout pinggoy Electric On-Road 3 05-07-2006 08:27 PM
rollout josh69162 Electric On-Road 5 07-04-2005 07:35 AM
Rollout loopedeloop Electric On-Road 6 01-30-2005 04:23 PM
SEO by vBSEO 3.5.0
