Rear Tires for Xray Factory RUBBING! HELP
I notice there are two holes on the rear shock arms for the Xray FActory kit. I am trying to run 28's on the back but the cause rubbing if i mount on the outer holes. Anyone have any suggestions as to how what i can do if i want to run 28 's and get the mount on the lower arms as far out as possible!
thanks
thanks
I run a FK. You have to remove 2 to 3mm of material off the arm where the shock mounts to the arm.
