Old 09-07-2011, 08:29 PM   #16
Originally Posted by RedBullFiXX View Post
There is no mechanical brake action with electric motors.
The esc can only drag the motor down to a low rpm, and that's all there is.
12th scale electric is all about corner speed, there is very little need, if any for brakes, especially at stock class speeds.
Since you're new to 12th scale, HERE is a link to tons of info on building and tuning your new car.
btw. Welcome to 12th scale, this is one of the most fun and inexpensive RC classes around
thanks for all the info.
tomekz is offline   Reply With Quote
Old 09-07-2011, 09:19 PM   #17
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
No problem.
Have fun
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-17-2011, 12:59 PM   #18
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by tomekz View Post
That is what I have been trying to figure out, what is normal. I am new to electric cars. I would have assumed that the once the motor stops spinning I would have a little more brakes than what I got though.
I guess I could live with it, however, one example where I am having issues.
Let's say I am going driving on a fast long straight and start braking at the end, the brakes work well enough to slow the car down, they stop the motor from spinning, however, than the car still moves because there is no resistance anymore from the motor and the car continues to move still too fast for the corner.
I think what you are looking for is "Drag" brake. That is adjustable on the SXX under Mode4.
YR4Dude is offline   Reply With Quote
Old 09-23-2011, 03:25 AM   #19
Start by testing this with another motor... Add some drag brake if you find you need more with specific motor. Different motors do apply different amount of brake.
Saying all that though, for 1/12th no brakes and nor drag brake!!! Only use a little brake incase of emergency...
As someone mentioned earlier, corner speed is important, and set-up so you can come on throttle smoothly but as early as possible out a corner.
This is all with Mod 4.0 / 3.5 T motors... So one thing I learned over the years with 1/12th... Apart from Practice Practice Practice... It is not a TC car, but in South Africa Nationals we have them run faster the n the Mod TC cars
Good Luck!!!
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
PHI/BMI racer is offline   Reply With Quote
Old 09-23-2011, 04:38 AM   #20
xray09ACT's Avatar
What you are experiencing is normal especially with the 12th.
Don't worry about it and drive you will find that the brakes feel harder as you go faster due tonthe rotating mass. Little speed little brakes.
ACE Hobby Australia | Monaro models
TEAM Associated TC6 | LRP | LRP
TEAM Associated TC6 | Nosram | Nosram
TEAM Associated 12R5.1 | LRP | LRP
xray09ACT is offline   Reply With Quote
Old 09-29-2011, 09:44 AM   #21
Infinite 12th's Avatar
Hi, it says here at LRP
Rec. Motorlimit Brushless	Forward / Brake
Voltage Input	3.7 - 7.4V
B.E.C.	over 4.5 turns
Dimension	30.5x34x16mm
input voltage	0.011V/phase
Weight (without wires)	30g
TwinBEC	6.0V / 3.0A
Does this mean only 4.5 can be run as minimum?
p.s. What is average turn for 12th
TQ - What is length and width of track and what might be motor (turn) selection for fast pace drivers
Norcal - What is length and width of track and what might be motor (turn) selection for fast pace drivers
Can a 3.5 motor work overall?
Thank you
Infinite 12th is offline   Reply With Quote
SEO by vBSEO 3.5.0
