Old 09-05-2011, 06:40 AM   #1
For_the_win's Avatar
Default Tekin rs vs LRP SPX Zero
Anyone have any pros or cons, Im only running stock class so no boost. Would the Lrp be good enough? Ive use 3 different Lrp Esc and have had no trouble once so ever.
For_the_win is offline   Reply With Quote
Old 09-05-2011, 09:33 AM   #2
mtveten's Avatar
Trader Rating: 27 (100%+)
That all depends on what you would consider good enough, for me the answer would be no. The SPX is an economy speedo and like any other budget speedo it isn't as smooth or linear as the higher end models. If you want to go with an LRP the SXX Stock Spec V2 is an excellent alternative to the tekin.
mtveten is offline   Reply With Quote
tekin rs vs lrp sxx stock spec mxracer458 Electric Off-Road 6 11-07-2010 10:05 PM
SEO by vBSEO 3.5.0
