shaft drive with batteries in the center
does anyone know what company this is a proto Type for.
whoops, forgot the pic
pic 2
pic 3
pic 4
Re: shaft drive with batteries in the center
Originally posted by JasonC does anyone know what company this is a proto Type for. -Dave;) |
very interesting desing:tire:
Its somebodys TC3. Look at the diff cases and lower arms. I wonder how high the roll center had to be changed to make that. All that work for a cool looking turd. What a waste.
I think they heard me when I posted this idea on the shaft/ belt debate thread a while ago.:cool:
Now if I would of patented the idea:cry: |
If i remember correctly it is a model from Japan, a company called Academy R/C. Had a customer in the navy bring one by for me to check out.
the downsides are the shaft are high up above the batts and the axles seem not horizontal. It is an interesting concept. :)
Originally posted by Speedie Its somebodys TC3. Look at the diff cases and lower arms. I wonder how high the roll center had to be changed to make that. All that work for a cool looking turd. What a waste. |
The center shaft has to be lifted up to give space for the battery and also the same for the front and rear diff.
Will this causes the overall CG also become higher? |
wierd......the servo is in the back of the car
the CG of this car will be too high, it might work for an off road buggy, but for a touring car i doubt it's centre battery positioning out weighs the downside of high CG.
Look at KX-One, battery is mounted above the belt, not good either |
