Old 09-02-2011, 07:57 PM   #1
Default What makes a locked rear diff better for drifting
I have a TT01 that I can drift very well. I got my transitions down and I get better and better but I am starting to wonder if a locked diff is really necessary.
What's the deal? Why is it always recommended when I don't even have it done but drifting is so easy now.?
All-Or-Nothing is offline   Reply With Quote
Old 09-02-2011, 08:07 PM   #2
If it's what I'm thinking about this is it:
Turn the tires of most RC's. The opposite tire will turn the opposite direction. This is due to the differential. The diff allows the tires to turn at different speeds when in a turn. The outside tire spins faster than the inside tire
Now a locked diff means that both tires will turn at the same rate. This leads to reduced traction and thus when turning at speed, the traction will break a lot easier than a normal diff
In off road conditions, a locked diff will give more traction because of the slower speeds, but with street conditions you'll lose traction because of high speeds
So for street you can break traction easily and be able to drift, as well as drift longer as the traction will pretty much be lost until you reach a a slow enough speed to gain traction back
Hope that helped explain it a little
;; Associated RC10T2 ;; HPI RS4 Rally;; Axial SCX10 ;;
Armistice is offline   Reply With Quote
Old 09-03-2011, 06:23 AM   #3
Yokomo DMAX - Daily drifter!
HPI SPRINT 2 - Wife's
Tamiya F104W
I live in japan pm me if you need something hard to find, I'm paypal verified!
Jdmpurest is offline   Reply With Quote
SEO by vBSEO 3.5.0
