Old 11-09-2004, 04:54 PM   #1
Default Capacitors and diodes how to install
I want to install a shottkey diode and some capacitors on my motor, what are the benifits of this and does anyone have a wiring diagram and the specifications of the caps and diode?
Any help would be appreciated, Thanks.
Snitch is offline   Reply With Quote
Old 11-09-2004, 05:35 PM   #2
GTO2's Avatar
R/C Tech Charter Subscriber
negative (white stripes) side of diode goes to positive of motor. The other goes to negative. Purpose is to protect your ESC from backflow current during braking.
If power caps the one you're talking about, just hook positive to positive of your batt (or positive of ESC in that sense) and similar to the negative. Value of cap depends on motor, effect you want to get. Better info, search online, sure bound to found one.
GTO2 is offline   Reply With Quote
esc's, capacitors, diodes, 540 pro J-PaP Australian Racing 3 02-21-2007 03:38 PM
Schottky Diodes macgyver1432000 Electric On-Road 4 03-19-2006 10:12 PM
Stockky diodes blueskieshlg Rookie Zone 2 02-02-2005 07:10 AM
Do I need to install capacitors on d6 motor? Hasee Electric On-Road 5 09-14-2004 09:33 PM
shockity diodes kh15 Electric On-Road 5 09-01-2004 07:35 AM
SEO by vBSEO 3.5.0
