Old 08-29-2011, 08:11 PM   #1
Swampracer's Avatar
Trader Rating: 67 (99%+)
Default Speedmerchant REV 6 build question....HELP?
I just got around to installing the carbon fiber link set conversion for my REV 6.
But the original pivot balls (threaded) do not fit in between the machined pivot sockets. Too big, major gap.
Any ideas? Or do I need to use different pivot balls from Speedmerchant?
Thanks for any input.
Greg G
Swampracer is offline   Reply With Quote
Old 08-29-2011, 08:30 PM   #2
Same exact pivots and threaded balls as used in the center pivot.
The gap really does not matter as long as there is no play between the link and the ball. They should rock side to side freely. You adjust the 2-56 screws in small increments.
JoelV is offline   Reply With Quote
SEO by vBSEO 3.5.0
