Old 08-23-2011, 01:15 AM   #1
Default Sanwa SRG-HR on 1/12 pan car
I just got this servo, it is saying prefect for 1/12 pan car. it is smaller size then regular 1/12 pan car servo. The SRG-HR comes with plastic plate for mounting with double side tape but using double side tape has too much play. Want to know if there is an alu adopter mounting between the chassis servo holes the servo ears? Hate to use double side tape on servo.
ioxqq is offline   Reply With Quote
Old 07-18-2012, 01:01 AM   #2
how did you solve the problem?
pedro77 is offline   Reply With Quote
Old 07-18-2012, 02:17 AM   #3
Well there is a couple of options...back in the day chassis came with no servo mount holes and we had to drill our own...you could always drill new holes to properly line up with the servo ears. Alternatively you can glue the servo in place using Shoe Goo if you are planning to run the servo flat on the chassis. You may have to make some sort of spacer though if the servo saver doesn't clear the chassis.
Old 10-26-2012, 11:43 PM   #4
CFR's Avatar
Seen it mounted like this in the UK in a Mardave GT12 chassis
see also http://www.bilder-space.de/show_img....&size=vorschau
Sanwa SRG-HR on 1/12 pan car-sanwa-srg-hr-servo.jpg
CFR is offline   Reply With Quote
Old 10-27-2012, 04:21 AM   #5
wingracer's Avatar
Trader Rating: 21 (100%+)
either drill new holes or shoe goo it.
Sean. Certified speed crazed mowron.
Team Shepherd USA
wingracer is online now   Reply With Quote
SEO by vBSEO 3.5.0
