Old 11-05-2004, 11:43 AM   #1
Default TC3 delrin shock bushings?
Anyone know if you can replace the Assoc. 6473 and 7217 with Trinity TK3047 or RPM 70181 (or other options?)
billwilner is offline   Reply With Quote
Old 11-05-2004, 11:54 AM   #2
Lebatek's Avatar
Send a message via AIM to Lebatek
The bushings in the first link you supplied should work fine on the lower end of all Associated shocks. I am not 100% sure about the second link's bushings...give it a shot.
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 11-05-2004, 12:30 PM   #3
The trinity listed item is not meant as a lower shock mount bushing. It is a replaceable bushing for the upper shock mount (the one that goes through the shock cap), which is a combination of an aluminum part and the teflon(?) bushing. Hope this helps.
TPJ International
071crazy is offline   Reply With Quote
Old 11-05-2004, 12:37 PM   #4
koabich's Avatar
Send a message via Yahoo to koabich
Trinity makes a shock bushing for the TC3...or at least they used too. The first link you posted should work assuming they are the right length and the balls are the correct size so they fit into the shock cap.
Here is the link, on Tower Hobbies, for the shock bushings. They are for Yokomo and I am not sureif they are the correct length for the TC3 but I use the TC3 versions and love them. The second link you posted are the replacement balls for this set up!
Hope this helps!
koabich is offline   Reply With Quote
WTB: KMW Bronze Shock Bushings fas86cutls R/C Items: Wanted to Buy 0 05-20-2008 10:31 AM
Delrin XXX4 Front Shock Tower nwilcox88 R/C Items: For Sale/Trade 6 08-29-2007 03:45 PM
WTB: LST Shock Stand-offs/Bushings arisking R/C Items: Wanted to Buy 0 02-21-2007 09:51 PM
Bushings vs Bearings Freddybnj_2004 Electric On-Road 5 11-18-2004 04:22 PM
bushings? SPC Racing Electric On-Road 7 03-06-2004 05:14 AM
SEO by vBSEO 3.5.0
