Belt Driven vs. Shaft Driven
#46
Torque steer is also dependent on the diffs of the car and traction on each wheel. So belts can suffer from Torque steer
Both belt and shaft have noise, its more likley the Frequency of the noise which makes it sound silent????
It doesn't matter what drive train type it is as long as it is free from binding and smooth (and a Tamiya )
#47
this is crazy wars : the shaft vs. the belts
I don't care as long as as the car moves forward
#48
Originally posted by bender
I'm sure there are a few people who understand what you're saying (i'm one ), but you appear to be so one-sided in your assesment that you are only stating facts that prove your point, yet there are other factors to consider.
Now I am not going to debate which is better, but I will add some facts that have been mis interperated, missed altogether, or just plain stated wrong.
Fact: Many belt cars don't use or need tensioners. Key word, MANY
Fact: Ball bearings, as efficient as they are, still create friction, and shaft drive cars have more bearings. True
Fact: Shaft drive's do suffer from torque steer, even though it is very minimal, and it is a result of an off-set longitudinally mounted motor. Correct
Fact: Noise DOES equal friction! When two surfaces of differing hardness/strength/material are rubbing together, they create less friction than two surfaces of the same material. Think about that when looking at the drive train of a belt or shaft car. False
Fact: friction losses in a shaft drive car are at their maximum at full speed, friction losses in a belt drive car are at their minimum at full speed, and vice versa under acceleration. False, the friction causes the belts to flex. How many teeth make contact w/ YOUR belt drive car's diff? Two teeth touch in a 39/16 shaft drive car. But you are right about acceleration.
It's all well and good to try and blind people with science to "win" an argument, but this doesn't make your statement any more believable when they are biased. Blind people? Win? I'm just trying to give physics LAWS to explain what creates friction in a belt driven car. I could do the same thing for shaft driven cars.
Bottom line: any advantage gained in one area by one type of drivetrain is lost in another area.
Result= belt and shaft are equal
#49
The only thing I have to say is I hope all the manufacturers don't go one way or the other... We need choices out there between belt and shaft.... I currently run a Yok SD and a TC3 and I'm looking to add the Xray to my collection soon....
#50
shaft drive 4 me
ive tried the losi xxx-s an i didnt like it much. so i got a tc3 an i love it.its seems so much easier to setup and to keep clean.but i want be upgrading to the tc4 just yet i see no reason to. my tc3 is fast an i put a lot of time in to it,ive did just about everything to my tc3 tahts done to the tc4/ackerman steering,batts moved in closer to shaft,open motor hole up,etc. well just my 2 cents
Steven Alexander
Steven Alexander
#51
shaft drive 4 me
ive tried the losi xxx-s an i didnt like it much. so i got a tc3 an i love it.its seems so much easier to setup and to keep clean.but i want be upgrading to the tc4 just yet i see no reason to. my tc3 is fast an i put a lot of time in to it,ive did just about everything to my tc3 tahts done to the tc4/ackerman steering,batts moved in closer to shaft,open motor hole up,etc. dont get me wrong belt cars r good for people who like belt cars,dont want to sound liek im downing belts cars but shaft cars suit me more(i guess watever u perfer).well just my 2 cents
Steven Alexander
Steven Alexander
#52
shaft drive 4 me
ive tried the losi xxx-s an i didnt like it much. so i got a tc3 an i love it.its seems so much easier to setup and to keep clean.but i want be upgrading to the tc4 just yet i see no reason to. my tc3 is fast an i put a lot of time in to it,ive did just about everything to my tc3 thats done to the tc4/ackerman steering,batts moved in closer to shaft,open motor hole up,etc. dont get me wrong belt cars r good for people who like belt cars,dont want to sound liek im downing belts cars but shaft cars suit me more(i guess watever u perfer).well just my 2 cents
Steven Alexander
Steven Alexander
#54
Well, shaft drivers can always say "Belties got Shafted". Works both ways
#55
I think due to layout, belt drive cars will always be more balanced than shaft cars. I use a TC3 for outdoor, and an XXX-S for indoors.
#56
Besides you can always add weight to the car to balance it.
#57
Originally posted by FlyinGT
Did u say hpi belts ?? the pro4 is a shaft drive ... an if u are talkin about the pro3 then u are goin way back
#58
Originally posted by Cole Trickle
You forgot the Pro2. Still going strong
but i heard it was a good car for it's time ...
Also note wat ppl have been saying ....
an it seems that most ppl are either on belt or shaft drive
now thats due to the fact that they have either one of them
an they have found it to b comfortable an easy for them to look after, they have exprienced it for themselves so for them a particular drivetrain will work best to their drivng style ..
the only real way of asking which is better is to actually try it 4 ur self, u may have different expriences to others
so like me trial an error until u find a car u like ...!!
the belt Vs shaft debate is pointless, if u don't have the skills it won't matter if u got a shaft or belt.
#59
