Old 11-30-2011, 12:00 AM   #31
303slowdown's Avatar
Trader Rating: 21 (100%+)
V-Dezign Carpet Ripper V-20111129172137.jpg. V-Dezign Carpet Ripper V-20111129172226.jpg
V-Dezign Carpet Ripper V-20111129172241.jpg. V-Dezign Carpet Ripper V-20111129172325.jpg
Current setup is
Front
Tire- jaco black 42mm
Spring- .050 no preload
Camber- neg 1.5
Caster- 5deg blocks 3 shims front 2 back of arm
Center
Shock oil- ae 55w
AE Blue center spring
Shock mount forward position (extention on shock)
Rear
20k tube lube (crc)
CRC white side springs 1/4 turn preload
2mm pod droop
Tire- jaco orange 43.5mm
3.5mm all around
Motor- thunder power
13.5 no timing
Car is very fast and has a lot of steering and corner speed
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-30-2011, 01:47 AM   #32
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Built My CRV few days ago, goes together well good quality parts as always
Ryan how come you used the Longer shock?? have you found the car is giving you better results over your last one?
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 11-30-2011, 02:05 AM   #33
I'm running the longer shock for the added steering it gives. I like a ton of steering in my setups. The car has a lot of steering with the shock in the rear possitions too but I like it better forword.
Ryan Borgheiinck
Old 11-30-2011, 12:36 PM   #34
Vesa's Avatar
Send a message via ICQ to Vesa Send a message via MSN to Vesa
Hi guys,
you can now download editable pdf-setu-sheet for CR V from:
http://www.petitrc.com/reglages/vdez...petRipper.html
New accessories added to the website, more to come!
V @ V-Dezign
Sponsored by: V-Dezign | Nosram | Reedy | Black Art | TQ Wire | Horizon hobby | Xenon Racing | Badger airbrush | RC-Trim.com
Web - www.v-dezign.net | Facebook - www.facebook.com/vdezign
Vesa is offline   Reply With Quote
Old 11-30-2011, 12:57 PM   #35
ByteStream's Avatar
I see Ryan's car first hand every week, and I must say the parts quality on the CRV is pretty impressive. It's all in the details .. the CF parts have their edges rounded off out of the box and the machining of the aluminum is excellent.
Well done Vesa.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 11-30-2011, 11:47 PM   #36
I'm new to 12th scale (been racing 1/10th scale offroad before) and got the Carpet Ripper V as my first pan car. I built the car with the manual to out-of-box setup and went to track and it was very easy to drive right from the start.
V-Dezign's parts are very high quality, black anodized aluminium parts looks awesome and carbon fibre has been machined nicely.
The CRV uses CRC's plastic parts and they need a little bit of work to get everything work smoothly. If you run in to problems with the car, Vesa is more than helpful to answer questions.
I'll be doing my first race this weekend, can't wait to get CRV on to race track.
Here's my car:
More pictures
http://www.finRC.com
AiR2k is offline   Reply With Quote
Old 12-01-2011, 05:33 AM   #37
Vesa's Avatar
Some of the new products from Team V-Dezign:
- Diff grease - less maintenance, superb performance - suits for all ball diffs
- Thrust grease - less maintenance, smoother diffs - suits for all ball diff thrust bearings
- Anti-wear grease
- Lite diff rings
- Rear axle shims
- Black alum rear wheel mounting screws
- Black M3x6mm button head screws
- Front end pivot ball tool
- Countersunk flat shims, black & red alum
- VDZN Tube oils ; Supersoft, soft & medium
and more....
Plenty of graphite parts in stock soon. Carpet Ripper V kits available again before Xmas! Also planning - if there is interest on this - to release upgrade kit which includes the rear pod and all graphite parts and pivots so it would fit any CRC car - just consider the color resistance from black to red
V @ V-Dezign
Old 12-01-2011, 12:33 PM   #38
tim fry's Avatar
Here's my car:
More pictures
Looks very nice
Whats the current price?
tim fry is offline   Reply With Quote
Old 12-02-2011, 04:12 AM   #39
Vesa's Avatar
Please email me for pricing and availanbility to info at v-dezign.net!
V @ V-Dezign
Old 12-03-2011, 02:24 PM   #40
Me_MrTyson's Avatar
Tested my crv yesterday at a local 8th scale track, long straight
More a power track with it current setup, went with kit setup with Small changes moved from 35wt to 25wt shock weight for more rear traction
Changed to gold side springs with little pre load about 1/4 turn
Car was dialed and the corner speed was unreal no need to go totally off throttle, lighter shock oil helped with the bumps on the track being outdoor
Had to leave but wanted to turn up the boost more and more it just had that much grip, this car really is so easy to be consistent
Tires tested
Xceeds soft rears and Jaco double pink fronts & body was AMR
Old 12-05-2011, 01:45 AM   #41
Me_MrTyson's Avatar
Default Decided to share a photo of my car
Old 12-05-2011, 01:50 AM   #42
Me_MrTyson's Avatar
sorry about the size.. never knew how big they where when i posted
Setup Sheet
Old 12-06-2011, 01:41 PM   #43
Blue Carpet Race 2011 was held last weekend at Kiiminki, Finland (600km north from Helsinki).
Here's A3 main of 12th scale modified. Vesa Yli (Designer of the CRV) and Panu Vehniainen had awesome battle.
+ YouTube Video
Old 12-08-2011, 05:05 AM   #44
Vesa's Avatar
New batch of bearings & diff balls in stock!
Just to let you know - new batch of CR V cars available before Xmas!
Upgrade kits for any previous Carpet Ripper - all graphite parts, links/pivots and complete rear pod included - available next week already!
V @ V-Dezign
Old 12-26-2011, 02:45 PM   #45
First outing of the season today and had a blast, car was so easy to drive even compared to V4. Need some work on ESC settings to have a little more grunt out of the corner.
Long shock option was best but need to check the droop on that for next time. Was running 5.5 turn mod and directly on last years pace, at the end a little faster and more consistent.
Setup sheet attached and this time hopefully full of info...
Greetz
Nilezb is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45699 07-24-2017 05:30 PM
Townsville Racing - TMORC Forum Sam Contarino Australian Racing 13652 06-16-2015 06:49 AM
