trf 415 lw suspension
I have the light weight suspension parts on my 415 but the spacing shims given on the build sheet cause the suspension arms to bind and not drop freely has any one else had this problem and if so what suggestions have you got? :confused:
Re: trf 415 lw suspension
Originally posted by hoppy I have the light weight suspension parts on my 415 but the spacing shims given on the build sheet cause the suspension arms to bind and not drop freely has any one else had this problem and if so what suggestions have you got? :confused: You can grind the shims a bit, untill they move freely. Grind the shims and not the arms, because when you mess up the rings are cheaper to replace then the arms:) Bye Thomas |
lw suspension
i woul sooner rearrange the shims then grind them down :eek:
