question about lipo charging
I have a Swallow Advance charger and it only can charger upto 5000mh lipo's according to the manual.
I have a battery that is 5600mh will it be ok to charge it or will I need a new charger? |
Originally Posted by J SiN
(Post 9484812)
(Post 9484812)
I have a battery that is 5600mh will it be ok to charge it or will I need a new charger? Chargers are rated at the max charge rate in Amps or mA they can charge at. Think of it like filling a bucket. The bigger hose you use, the faster it will fill. If you wanted to charge a 100,000mAh battery with it you could, it just takes more time. Remember to always check the battery specification to see what the maximum recommended charge rate is. if you have a low capacity battery, it is possible to do damage to the battery by charging at too high of a charge rate. Kind of like filling a spoon with a fire hose. |
I could be wrong but I don't think this has anything to do with charge rate. I think it has to do with charge TIME. Most chargers will only charge till the battery reaches a full charge, is fully balanced (assuming you were balance charging) OR for only a given amount of time based on maximum mah. In other words...if the battery just won't reach a peak charge or balance, the charger will keep trying for a given amount of time before it simply "times out".
I have to wonder whether a 5600 could reach it's peak rate when the charger is only set up for a max of 5000mah. ?? |
Thats what I was thinking.
I will use the charger until I can afford a newer one. Thanks for the help guys |
Originally Posted by Evoracer
(Post 9487316)
it will charge fine, unless your discharging your batteries to far you don't use the entire capacity. safe bet is around 80% discharge.
you will probably find you only put 4,000-4,500 mah back in. worst comes to worst if it hits full capacity just restart the charger. on a side note, just check as some chargers allow you to adjust the capacity up a bit. |
