Old 12-16-2013, 05:27 PM   #151
Soundstream's Avatar
Send a message via Skype™ to Soundstream
I was just wondering if anyone has tried to put a shock in the front similar to the yokomo. I would like to try this for fun but am interested to see if anyone has done this.
Team Terribles Member
Tamiya 801Xt, Robitronic Mantis, Robitronic Avid, Robitronic Scalpel, Robitronic Protos, Sportwerks Mayhem pro, HPI Nitro RS4 3 EVO+ RS4 Drift, HPI Micro RS4, Sportwerks recoil, Sportwerks Raven BX, Losi Aftershock, Losi NXT, Associated RC10R5, Associated NTC-3, Spektrum DX3R pro, Radiopost module system.
Soundstream is offline   Reply With Quote
Old 12-16-2013, 06:04 PM   #152
The Yokomo has a center front shock option because it uses a double wish bone front suspension, both the upper and lower suspension arms move. The Kyosho front end is more traditional so the lower arm does not move like most 1/12th scale cars. Since the shock is attached to the lower arm it wouldn't do much good since the arm doesn't move.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 12-26-2013, 11:36 AM   #153
Wow, Thank you for the info!
Old 12-31-2013, 08:21 PM   #154
Default 50th anniversary edition?
Hi guys and gals, looking at buying a plazma ra. Is there much difference between the older version and the newer 50th edition? Instead of buying a good ra should I spend the extra and buy the 50th edition?
Thanks, Paul.
Kyosho RRR /futaba 3Pk/OS TG/Novarossi S12/ Savox/Soon 2B R4..
CRC xti / Orion R10 /Trinty D3.5 17.5t
TLR XXX-TCR basher...
Friday night, fight night....rc racing, that is
Team FTR.
volumex is offline   Reply With Quote
Old 01-05-2014, 06:26 AM   #155
gelshocker's Avatar
Hey guys, can I fit the Yokomo GT500 bodies to the Plazma? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 01-06-2014, 02:03 AM   #156
AllenCheung's Avatar
Can't view the pic, but new 12th scale cars are always welcomed
AllenCheung is offline   Reply With Quote
Old 01-06-2014, 02:05 AM   #157
Kyosho Plazma 1/12th pan chassis
What kind of Battery do you choose? with lines?
Old 01-06-2014, 07:33 AM   #158
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
GT500 - 10th scale
GT300 - 12th scale
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-11-2014, 06:35 AM   #159
We run 1s lipos.
Quick enough for all motors!
Neil Skull is offline   Reply With Quote
Old 03-21-2014, 08:32 PM   #160
Default Gearing
Hi All,
I was hoping for some gearing tips. I've only run the car a couple of times now (Team Orion Vortex 3.5T & R10 ESC) and I have the thing apart right now and it looks like my pinion & spur are a little stripped. I'd like to replace them with a more durable option that reduces the acceleration a bit...I'm having some trouble finding compatible options. Any recommendations?
Thanks!
sundevil67 is offline   Reply With Quote
Old 03-21-2014, 09:12 PM   #161
Car Breaker's Avatar
we ran Kawada 18 ball spur using 4.5t motor on asphalt here, they are durable. to reduce acceleration, run bigger pinion, or simply tune down the punch on your esc
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 04-06-2014, 09:09 PM   #162
EDWARD2003's Avatar
Here's a really good setup for 21.5 2 cell medium traction asphalt setup. Track surface temperatures were around 30~40 degrees Celsius.
2.25 mm chassis for increased chassis flex (front brace installed)
Front
Camber -1.5
Caster arm forward
Spring 0.20 Associated
Kinping Oil 30,000 Kyosho
Ride Height 3.8 mm
Medium Hard Team Bomber Tires (43.5 mm dia)
Rear
Center Shock 70 wt oil (Kyosho 700)
Associated Gold Spring
Center shock mount (standard)
Damper tubes (20,000)
Associated silver side spring
Ride height 4.0 mm
Medium Soft Team Bomber (45.00 mm)
I found this setup carried a lot of corner speed with lot's of steering. Best setup I've found so far.
EDWARD2003 is offline   Reply With Quote
Old 10-23-2014, 06:17 PM   #163
EDWARD2003's Avatar
Dusting off this old beast and giving it another go. I've learned heck of a lot about setup since I purchased the Yokomo C3. I wonder if I can run the Yokomo C3 front suspension on the Plasma Ra?
Old 03-07-2015, 05:41 PM   #164
I have one of these coming to me. Can't wait to try it out.
XCRAZYBENX is offline   Reply With Quote
Old 01-24-2016, 07:13 PM   #165
lbckevin's Avatar
Trader Rating: 85 (99%+)
Is this 12th scale still competitive ? There are a couple for sale, should I go for it or get something else.
Kevin Smith
Schuur Speed* Hobbywing * Pro-Line * MIP * Paint Monster Airbrushing * Schelle Racing
lbckevin is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45574 Today 08:05 AM
Will there ever be a 1/8th scale Electric onroad car Raydee Oval, Larger Scales and More 1259 03-20-2017 11:27 AM
1/12 scale Racing Badman Racer Australian Racing 1111 09-16-2014 02:22 PM
