Old 10-28-2004, 11:25 AM   #1
Default GM V3R problems
Hi, I have GM V3R ESC.
The servo works fine but the throttle and brake does not work.
Is it possible to reset the V3R ?
The green light comes on when I turn it on, when I brake and throttle the green light stays on.
What could be the problem ?
Plz comment
Snikkari is offline   Reply With Quote
Old 10-28-2004, 12:38 PM   #2
sosidge's Avatar
The V3R doesn't remember it's settings - to be on the safe side you have to do a quick wetup every time you switch on.
To reset the speedo, switch off and unplug the batteries.
Then, with your transmitter on, plug in the batteries and switch on the speedo.
The FIRST thing you should always do when switching on is to go to full forward throttle. The SECOND thing you should always do is go to full reverse.
The speedo is now set.
In theory, it should remember these settings, but it can't be relied upon - you do need to make sure you use full forward power FIRST. Never use reverse directly after switching the speed controller on, it will mess up the settings.
If it nothing works at all, it could be a damaged speed controller.
b4/t4 problems trdsupra88 Electric Off-Road 12 03-15-2008 09:52 PM
JR Z-1 Problems...need help! pumpkinfish Radio and Electronics 3 10-24-2007 04:31 PM
Problems.. Oasis Chat Lounge 9 01-16-2006 07:41 AM
tc3 one way problems dontfeelcold Australian Racing 7 12-31-2003 03:34 PM
Set Up Problems Griz Australian Racing 5 12-04-2003 11:44 PM
SEO by vBSEO 3.5.0
