New Sakura XI
#46
Just ordered mine. Hopefully it doesn't take too long to show up. I really like the original Zero (I even sold my TRF417 in favor of my Zero), so I'm hoping the XI lives up to (or even surpasses) its predecessor.
#48
A driver here in Sydney is reporting his Sakura X1 is generating plenty of grip
#51
First test of th XI on a proper track with medium grip and all i can say is wow
massive grip so much i had to go extreme on springs running second to hardest in 3racing spring set and 550 oil all round and still could of gone harder.
all i did from stock setup to get car really good was .5mm of antidive and raise camber links on front and rear by 1mm .
With more testing this car will be even more awesome than it already is
#52
Flip
Not sure if you ran a Zero but would you say the X1 is significantly better than a Zero with narrow chassis and the narrow rear end mods?
#53
Anybody got any pictures of their Sakura xi setup's or any new feed back on the cars. What major parts do I need to convert my Sakura zero to xi I already have the motor mount rear narrow arms and rear hubs what else do I need
#54
XI has narrow front and rear arms and standard toe blocks .
The new rear bulkheads have integrated belt tensioner and new eccentric system.
The new sakura is great car with great grip with kit ish setup car has too much grip i had to make car stiffer to work better.]
will post some startup setups soon
#55
having a hard time deciding,hope someone with alot more knowledge can help me out.heres what i'm thinking, trf417 big bucks still no independant motor mount,t3 2011 people still complaining about shocks,tc6 is still just a tc6,s411 looks good but been reading has sloppy steering,and then i found out about the x1.this car seems to be just as good as the formentioned.i guess what i'm asking is,is this car really that good.construction,parts availability,durability,drivability,etc. thanks
#56
just built my car, quality is really good, everything fits perfectly..no dremel required! quality is on par with the other big brands out there.
only downside is that the upper bushing in the shocks has too small diameter, which causes the shaft to move sideways.. have ordered the tamiya parts ($5) and i will change them asap,
havent raced the car yet but i have only read good things about it
also, the pink alu looks really nice
#57
Yes more detail setup !
#58
Will they release a Sakura XI S?
#60
Gents,
I spend sometime doing an editable setup sheet for this car, find it here.
I wish i can add some weight's positions on the lower desk, can you provide (either by PM, e-mail or on this thread) some ideas of where you locate those items? Pictures welcome to ease the understanding.
