Digital Servo Question
Hey all...I have a question that someone may be able to help out with...
I have a KO Mars. Original model (orange handle type). I want to use a digital servo for my steering...Do I need a special Rx with a digital servo...or can I simply buy the servo I want and not worry about it? My Rx is the KO Propo KR-297FZ. Thanks, -Soviet |
you can use a digital servo no problem,
if you update to one of the new radios (HELIOS) then you HAVE to run digital servos, but you'll be fine Mo |
Originally posted by 1fastguy1 you can use a digital servo no problem, if you update to one of the new radios (HELIOS) then you HAVE to run digital servos, but you'll be fine Mo |
im runing Ko pro 2343 servo with my Sanwa M8 tx and 311 rx.
but i can hear some funny noise from the digital servo.are they compatible? whats the problem with my servo? |
Originally posted by KREATOR1 im runing Ko pro 2343 servo with my Sanwa M8 tx and 311 rx. but i can hear some funny noise from the digital servo.are they compatible? whats the problem with my servo? |
Re: Digital Servo Question
Originally posted by Soviet Hey all...I have a question that someone may be able to help out with... I have a KO Mars. Original model (orange handle type). I want to use a digital servo for my steering...Do I need a special Rx with a digital servo...or can I simply buy the servo I want and not worry about it? My Rx is the KO Propo KR-297FZ. Thanks, -Soviet I'm using a KO PDS 2123 with my 297Z. |
servo torque
I have looked at numerous threads about servos and I hear people reccomending 60 oz/in or even 80 oz/in on the torque for 1/10 electric touring.
Is that much torque really needed for steering? I had this stock Futaba servo 3003 it rated 44 torque Right now I am using a older Futaba s132h it is rated at 25 oz/in torque and .13 at 6 volts. If the reccomendations are correct than my servo is a bit weak. ---------------------------- What about the micro servos some of them are very cheap and have a speed of .09 and torque of 42 (Hitec HS81MG $23.49)? |
You want a high amount of torque to keep your wheels pointed where the radio is telling them to go. Furthermore, the speed of a servo says very little about its performance under higher loads. So, two servos may have the same rated speed, but a higher torque servo will probably perform better. For that reason, you will rarely see someone use a 1/12th scale servo in TC.
You'll always have mixed reviews with hitec servos. If it works fine, then great! But, you may want to save up a little more and get a KO, airtronics, or futaba servo. The complaints on these brands tend to be fewer. |
