need help on removing a stripped screw head
i have a few stripped 1.5m hex screw that i cant remove off my chassis and i dont want to damage the chassis it self any ideas ?
Originally Posted by nitroharry91
(Post 9439845)
Where is it?
if it isnt that bad i use imperial as its a little larger than metric some times works.
You have two options, both requiring some tools...
The first one is to use a dremel with the smallest diameter cutting wheel you can find. Dremel a slot into the screw head and remove the screw using a normal flat blade screwdriver. You do need a fairly small wheel though otherwise it will be difficult to cut a deep enough slot without cutting into the chassis. The second option is to drill the screw out using a pillar drill. If they are M3 screws, drill them first using a 2.0mm drill then a 2.5mm drill. The screws will usually collapse and come out with the 2.0mm drill, leaving a nice clean hole. You will need a pillar drill though, a hand drill won't do the job. |
hi if the bottom deck is carbon fiber then holding a very hot soldering rod on the head will 90% of the time will releases it if the hex is not completely rounded.there are many of ways to do it tho i prefer to slot the head with a dremel then use a flat driver to get it out
Getting screw put
Heat the threaded screws up, soldering iron as previously suggested will work, or even heat the driver up with a flame from a gas hob or something similar. Works most of the time. If not, you'll just have to drill it out.
Originally Posted by Joat
(Post 9439877)
Is it thread locked?I use torx, the craftsman easy outs and reverse drill bits, and sometimes standard hex keys
Originally Posted by rc_square24
(Post 9439879)
Where is it?
Originally Posted by P.I.M.P
(Post 9439935)
(Post 9439995)
Nope its not thread lock
Under chassis and top deck your solder iron method works on a few screws any other method beside using a dremel? |
would a engraver pen work?
