Old 10-24-2004, 12:17 AM   #1
FREAKAH's Avatar
Default Take-Off Tire Gluing Method?
While preparing to glue up a set of Take-Off CS-37's, I noticed that one side of the tires bead has more flat contact surface area than the other as the other side(where "MADE IN JAPAN" and "TAKE-OFF" is printed)is slightly rounded. The side where "CS-37" is printed is flatter. I am talking about the part of the tire that contacts the outer ridges of the wheel.
I glued up many tires before(mostly Sorex, Yokomo and HPI) and I never noticed there was a difference in the bead areas.
Did anyone else notice this on Take-Off tires?
Is there a purpose for the slightly rounded bead area?
Maybe the rounded bead side allows more glue to fill the area making it stronger?
Which side of the tire faces out?
I'll wait till some of you chime in before I glue them up.
Thanks in advance!
Second-Hand Racing
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 10-24-2004, 03:06 AM   #2
Eirik's Avatar
I have been told that CS37 should be facing out.... It has something to do with the belting as well.
Eirik is offline   Reply With Quote
The art of tire gluing. CE28N Electric Off-Road 15 09-12-2008 05:53 AM
tire gluing help needed...please!!! mike williams Nitro Off-Road 16 06-03-2008 06:21 PM
Tire Gluing acutts Electric On-Road 15 06-01-2005 04:04 PM
tire gluing scotwithonly1t Electric On-Road 9 11-07-2004 12:35 PM
Foam Tire gluing question sands Electric On-Road 1 11-06-2003 04:52 PM
SEO by vBSEO 3.5.0
