Old 07-17-2011, 10:27 PM   #1
Default Combination for Spur Gear and Pinion Gear
i need your advice for the combination for Spur and Pinion Gear. I have Orca 11,5 T and ESC SXX stock specs. Currently, I use 64 pitch 103T for the spur gear, what is the pinion gear I should use?
Thank you
BBP is offline   Reply With Quote
Old 07-18-2011, 02:53 AM   #2
wollow86's Avatar
More info about your track will help get the question answered. Layout, size, grip level and surface type, with a description or picture would go a long way to help. I'd say for zero timed your ballpark would be say 5-5.5 FDR. But it REALLY depends on your track.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
SEO by vBSEO 3.5.0
