Ta04r...
#1456
Hahaha......I guess Tamiya has finually noticed their mistake.....or is this a marketing ploy!!??
#1457
I believe it is more of a marketing ploy. With those short spings we should have more room for a lower ride height, but what are other pros and cons. I remember way back, Tamiya release short springs that are 23mm in height (neon colors) versus the 26.3mm we currently use.
#1458
Just a quick question for all the experienced TCS racers, I already bought a set of B2s for the upcoming July TCS race in Maryland, the track is medium grip asphalt, What inserts should I use?
I was thinking medium. What do you guys think?
Thanks.
Thanks.
#1459
Thanks.
Thanks.
JC
#1460
Have you ever noticed that the white and the blue in the 4 spring set are the same. Have you noticed they are missing whites in the new 4 spring single color sets. That might be a bigger ploy...
Coop
#1461
04 spring talk & SSG parts
The latest spring are not a maketing ploy in my opinion, Tamiya produced the new SSG shock tower in a much lower config. than the graphite or stock plastic towers.
Bottom line the stock springs are too long for the new SSG towers...unless you like a ride height of around 7mm
Best way to fix the design mistake (yes, I think it was a mistake) is to release a new set of springs
I recently put the new ssg chassis parts on my 04R and ending up having to remove the adjust. collars off the shock and go old school with shims to adjust the ride height to the level that works well at Tamiya America. The top plate I received is also slightly longer than the graphite unit making the front belt too tight (nothing that soaking the belt in WD40 won't cure)
Do the new parts work? yes. (TQ & win in a recent TCS GT3 event) but they require more "hand fitting" than I like.
JC
#1462
#1463
Originally posted by madjack
There was much B2 testing last year during the Nats week..and I believe that the majority of the A main racers were running the standard insert (the air gap helps) during the event.
JC
JC
#1464
I'm sorry if this is a dumb question Madjack, but exactly which ones are the standard inserts?
It has been a challenge running the b2's to say the least...but it is the tire we all must work with for the Nats (unless the rule change)
JC
#1465
Yeah, it's a shame they discontinued the old Bs I've heard a lot of folks complaining about the B2s, but like you said it's what we've got to work with, unless you got a set of the old Bs stockpiled somewhere. Thanks for the info Madjack.
#1466
Coop
Coop
Associated White 40.4
Associated Yellow 33.8
Associated Purple 31.2
Associated Copper 24.6
Associated Red 23.2
Associated Gold 18.8
Tamiya White 16.5
Associated and Tamiya Blue 16.3
Associated Silver 14.5
Tamiya Yellow 13.0
Tamiya Red 11.8
Associated Green 11.5
#1467
#1468
that chart is very helpful linger, I'm sure a lot of people can use the info.
#1470
Originally posted by linger
Actually, the white springs a barely stiffer than the blue springs....well maybe not. only 1.2% stiffer. I posted this a while ago on the EVoIII thread, but it's worth repeating. These were measured on a material test system. All units are in in/lbf
Associated Red 23.2
Tamiya White 16.5
Tamiya Yellow 13.0
Tamiya Red 11.8
Associated Red 23.2
Tamiya White 16.5
Tamiya Yellow 13.0
Tamiya Red 11.8
When you tested did you use new or used springs. Did you ever get around to the Tamiya Gold or 3 spring tall/short sets for testing?
Ok I will do some small bragging, I do have 3 sets of Bs never used or mounted. I could be sitting on a goldmine if they lift the tire rule for the nats... LOL
Coop
