Old 05-08-2003, 06:23 PM   #1441
Barry White's Avatar
dtm, do you have this problem with both shocktowers or only with one. Also I noticed they have one more adjusting hole but are they also thicker than the old carbon shocktowers?
Barry White is offline   Reply With Quote
Old 05-08-2003, 07:04 PM   #1442
dtm
dtm's Avatar
Send a message via ICQ to dtm
Barry- The front is slightly better..you can go down to 5-6mm ride height
I installed some Serpent front springs on the car now which are about 4mm shorter than the Tamiya ones. Hope these work...
The SSG shock towers are thicker than the original carbon, but they are still more flexible due to the SSG material!
dtm is offline   Reply With Quote
Old 05-08-2003, 07:06 PM   #1443
dtm
dtm's Avatar
Oh yes...the extra hole allow the shocks to stand up more vertical....not much use for the back if you are having ride height problems already!!
Old 05-08-2003, 07:53 PM   #1444
psycho's Avatar
Holy cow! You're using Serpent springs? I hope you have a set of orange or white. I think those will be way too hard unless you're running foams on carpet. The fronts are progressive to boot! Good luck.
psycho is offline   Reply With Quote
Old 05-08-2003, 08:47 PM   #1445
dtm
dtm's Avatar
The Serpent whites are a little softer than the Tamiya Yellows and the Serpent Yellows are slightly harder than the Tamiya whites...I'm only using the Serpent fronts because they are shorter.
Old 05-08-2003, 11:17 PM   #1446
rough512's Avatar
Originally posted by Difuser
Don't bother using the plastic. On the old (pre-threaded) shocks I did not use the plastic insert just the pre-load clips(or none) and spring. And they will not slip or fall off
The turn dial is approx 1.5 mm so this should get you low enough
Yes, but I feel better using the plastic insert as it centers the shock body inside the springs. This should prevent the sping from rubbing against the shock body.
rough512 is offline   Reply With Quote
Old 05-18-2003, 08:55 PM   #1447
Kenneth Tan's Avatar
Regarding the Spring length problem that DTM highlighted, has Tamiya actually resolved this? Quite weird that Tamiya makes a mistake like this....
Kenneth Tan is offline   Reply With Quote
Old 05-19-2003, 07:13 AM   #1448
lem2's Avatar
Default shock position
hi Guys! Have you noticed that we can't position the front shock in an upright position. Well it seems that my other cars handle better with the shocks almost standing up and I figured out how to do it in my 04-R.
and have you also noticed that the rear shock tower flexes, and the front seems to be more solid than the rear so why not use the front tower at the rear?
lem2 is offline   Reply With Quote
Old 05-19-2003, 08:36 AM   #1449
dtm
dtm's Avatar
Interesting comment about the front tower at the back! I found that the top of the gearbox does most of the flexing in the rear...that is with the normal graphite towers...with SSG it is definately the SSG that does the flexing!
The Serpent springs has solved my problem with ride height...yellows up front whites in the back. The car runs even better now (solved an on power understeer problem)....but that may be because I am "forcing" more caster to the front C hubs by running a shorter support turnbuckle!
Old 05-19-2003, 11:07 AM   #1450
Kenneth Tan
Looking at the 2 carbon to SSG the towers are completely different in gearbox to shock location heights. Something in the TRF is lower in the gearboxes or hinge locations this would be the only thing I could think of to make the difference. The parts were not meant to interchange?
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 05-19-2003, 06:27 PM   #1451
This is bad. So looks like I might need new bulkheads... Sigh....
Old 05-20-2003, 04:23 AM   #1452
dtm
dtm's Avatar
Difuser- Nop..the TRF will run into the same problem. If you come across one..check to see if they are using the inner holes on the A arms to mount the shock! The guy running the TRF on my local track was also running almost 7mm ride height....I guess thats the price you pay not to scracth the chassis!!
Old 05-20-2003, 07:44 AM   #1453
lem2's Avatar
Default Rear Tower
the rear shock tower is too tall thats why it is flexing. so I got a graphite front shock tower and place it in the rear.
look what I did witht he rear, sorry am onlyusing a web cam.
Old 05-20-2003, 08:42 AM   #1454
One of the guys going to Reedy this weekend is going to run the car he knows it alot better than his EVO.
I'll take a look at it and see if I can find anything not sure why they would raise the car so much.
Scratches you would cringe if you saw the bottom of my EVO it looks like hell. My 04 's look the same I'm not bottoming out I am just clearancing the chassis one bit at a time(hah)
Dan
Old 05-20-2003, 06:38 PM   #1455
I noticed something when I was browsing at Rainbowten. In the R/C News Section, I saw there new TRF Short Damper Springs rated in soft, medium and hard that are supposed to be released by Tamiya on 1st of June. Anyone thinks that this is the missing piece to the Great 04 SSG Ride Height Mystery?
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
