Old 04-21-2003, 11:08 PM   #1396
Steevo's Avatar
Originally posted by PizzaDude
Hi Steevo,
You're the real weightwatcher here, hahaha...
Well I'm interested in ALL the new parts.
Maybe we can put together some kind of table with original part/hop-up/newTRFhop-up.
And then with + or - weights for the weight gain-loss.
Personally I need to loose some weight fast.
BTW My car also...LOL
CU
Pizza
Too much Pizza Hut i'd say mate
I'll see what I can do. A friend of mine has the TRF version so I'll see if I can convince him to part with his car for a day.
I think you just solved my delemma on what to have for dinner...
Where's that Domino's Voucher
Steevo
Steevo is offline   Reply With Quote
Old 04-22-2003, 09:35 AM   #1397
PizzaDude's Avatar
bon appetit
PizzaDude is offline   Reply With Quote
Old 04-24-2003, 04:50 PM   #1398
awtwac's Avatar
Default Well...
The kit came together yesterday. I know, long time, but I had to wait for a couple of new purchases to get here so that I could put them on the car.
Problem is, my front diffs feel like crap! I've degreased and "rebuilt" it once and still feels very gritty. Rear is smooth as glass. What the hey is going on? One theory is that I didn't spin the diff while tightening, so may have dimpled the diff plates. Any ideas?
Regardless, can't wait until Saturday
awtwac is offline   Reply With Quote
Old 04-24-2003, 05:47 PM   #1399
Steevo's Avatar
Your diffs will usually feel a little gritty when new. After a few runs they will wear in and probably need readjusting slightly.
Something you may check is the diff washers or "Plates" They will usually have one side that is slightly more polished than the other. Make sure that the polished sides are the ones that come in contact with the diff balls. If you are still not satisfied you can polish the diff plates with super fine grade wet and dry and water.
Steevo
Old 04-24-2003, 06:32 PM   #1400
izzyracer's Avatar
Trader Rating: 27 (100%+)
I use the anti wear grease on my ball diffs. It will feel sticky at first but ones it breaks-in, you will have one smooth diff
Izzy
izzyracer is offline   Reply With Quote
Old 04-24-2003, 08:15 PM   #1401
psycho's Avatar
Here's what I do to get super smooth diffs. Build the diff per the instructions and put a small dab of hobby grease (stuff that comes in the kit) on each diff ball before assembly. Put one outdrive in the chuck of a variable speed drill. Don't over tighten the chuck because you don't want to bend the outdrive. Hold on to the pulley and run the diff for a minute or so with the drill. Keep the rpms down and if the diff starts to slip, stop immediately! You don't want to heat up the pulley or the plates and cause the plastic to melt. After a minute or so of running each diff in, I take them apart and clean out the old grease. It will be greyish in color. Re-lube with hobby grease, reassemble and you should be able to get the diff tight enough so it won't slip and still run smoothly.
psycho is offline   Reply With Quote
Old 04-25-2003, 11:31 AM   #1402
awtwac's Avatar
Thanks guys!
Old 04-25-2003, 12:01 PM   #1403
Regional Moderator
Send a message via AIM to Mike F
Default TCS July 13th in Memphis, TN
For those that are attending, go to this site for more information on Hotels Rooms. Get them while they last MSRA TCS HOTEL INFO
Mike F is offline   Reply With Quote
Old 04-25-2003, 05:35 PM   #1404
by adjusting the thread shock, what does it do to do the shock ?
zoombie is offline   Reply With Quote
Old 04-25-2003, 05:49 PM   #1405
izzyracer's Avatar
Do you mean the spring tension adjuster.
Your initial reaction will probably to use it to create more pressure to the springs thus making it firmer, but this is probably not the proper purpose. if you want to stiffen your setup use firmer springs instead.
Some people will use it help in getting rid of tweak by creating different pressures on each shocks in hopes of creating overall balance, but other says it will actually worsen the balance of the car because it is not equally distributed and you did not really get rid of the tweaked chassis. I just use them to make sure the springs is not floating in the shocks and i try to make at least the opposite side equal length.
Izzy
Old 04-25-2003, 05:56 PM   #1406
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Talking
Hmmm.... good answer.... hehehe!
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 04-25-2003, 06:10 PM   #1407
Default Web site
Here is a good web site on about Tamiya
Vintage Tamiya Radio Control Cars through to Modern Tamiya R/C - Home Page
message or move to Select a Folder----- Folders ------InboxDraftsSentTrashBulk Mail---- My Folders ----blackSaved
Back to Inbox | <Prev Next>
As AttachmentAs Inline Text
rowdyrj is offline   Reply With Quote
Old 04-25-2003, 08:38 PM   #1408
psycho's Avatar
izzyracer
You're on the right track, but it's actually a lot simpler than that. The collars on the threaded body shocks do exactly the same thing as preload spacers on the older or lower end cars. They are used to adjust the ride height of the car. In order to have the car handle right, you need to make sure the car is balanced correctly and you end up doing fine adjustments to adjust the "tweak" on the car too, but the main purpose is ride height adjustment.
Old 04-25-2003, 09:30 PM   #1409
izzyracer's Avatar
Originally posted by psycho
izzyracer
Psycho! haha that's a classic but great name! scary! anyway, you are right they are also use to adjust ride height. But if you use it that way you also affect spring tension thus can create other issues. A good way to adjust ride height is by using spacers (plastic or rubber) inside the shock cylinder during assembly to make your shocks shorter depending on the length of your spacers which will dictate your ride height.
In other words this thing can create a lot of affects both bad and good when use properly or improperly. OH MY gOD!
Izzy
Old 04-26-2003, 04:47 PM   #1410
psycho's Avatar
izzyracer
It's a long story on my nick, but it has nothing to do with me actually being psycho! The trick with the spacers or o-rings inside the shocks is actually a trick to reduce the amount of droop or suspension down travel. You shouldn't ever use droop control to adjust the ride height. Since the TA04 has a droop adjustment on each arm, there is no need for any spacers inside the shock. You're right about using the collars to compress the springs. It's not a good idea since you lose all of your suspension downtravel. Anyways, I hope that helps clear things up!
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
