Old 02-28-2003, 05:18 PM   #1216
has anyone tired running a normal body ont eh tao4-ss(short wheel base)? i mean you could just cut teh wheel weels shorter to align it witht eh short wheel base right? i really don't wanna just run the mr-s or tt, i want to use my 190 bodies but mod it to fit.
would that work? has anyone tried that?
thanks
sengming is offline   Reply With Quote
Old 02-28-2003, 05:54 PM   #1217
Should if the body doesn't taper too much at the waist
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 02-28-2003, 08:41 PM   #1218
Iso Octane's Avatar
Protoform bodies' wheel bases are already too long... with the SS you won't be able to see rear wheels . Think of it as an aerodynamic enchancement.
Iso Octane is offline   Reply With Quote
Old 02-28-2003, 08:50 PM   #1219
waht about hpi adn tamiya bodies?
yea i'm gonna get a set of ta04-ss arms tommorrow and hook tehm up.
i don't want to buy a mr-s so i'm might get like a hpi civic?
thanks
Old 02-28-2003, 09:05 PM   #1220
izzyracer's Avatar
Trader Rating: 27 (100%+)
any std body will not look right on short wheel base. I have the MR-S and I think it's an awesome body. What about the new Audi TT for SS
izzyracer is offline   Reply With Quote
Old 02-28-2003, 09:48 PM   #1221
well i kinda like the mr-s but i don't want to spend $70CAN for it. do you think i should trade in my tamiya new 2002 nsx unpainted body or a toyota celica unpainted for a mr-s?
thanks
Old 03-01-2003, 12:14 PM   #1222
Regional Moderator
Send a message via AIM to Mike F
Originally posted by Difuser
The small end of the countersink is the same, the large end is larger so it will lock it into place just not sit flush with the graphite plates
I follow you.
I installed the graphite towers last night, shoo goo the rear to the diff cases. I did notice on the rear graphite shock towers that it sits very low. It almost looks as if the bottom of the rear towers is touching the rings on the derlin outdirves. Has anyone notice this?
Mike F is offline   Reply With Quote
Old 03-01-2003, 12:51 PM   #1223
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Yes I took the dremel to mine a little bit and just made sure it would clear.
KINGZJ is offline   Reply With Quote
Old 03-01-2003, 09:14 PM   #1224
Regional Moderator
Thanks. That fix the problem.
Are you using the belt tensioner?
Old 03-02-2003, 12:24 AM   #1225
moshmike's Avatar
hey buggZI!
The ssg parts are not only just eye candy. They are actually reinforced with aluminum pieces to make the carbon fiber stronger for less flex. There were a lot of complaints about how flexable the old c.f. is. They also have a cool gray shiney look to them-eye candy.
My most high tech car is a TA-03.
moshmike is offline   Reply With Quote
Old 03-02-2003, 10:18 AM   #1226
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Originally posted by moshmike
hey buggZI!
Aluminum... had not heard that one yet?
If you want to make them stiffer why not add more layers, different materials ...kevlar... etc.
I would think the addition of aluminum into the mix would make the pieces more likly to tweek or bend?
madjack is offline   Reply With Quote
Old 03-02-2003, 06:51 PM   #1227
Regional Moderator
Ran my 04R today for the first time, on the track that is. The car was hooked. Some other cars were getting lapped . I'm very please with the perfomance.
Old 03-03-2003, 08:19 PM   #1228
jackhammer74's Avatar
Originally posted by Mike F I haven't actually placed the car on the track so my set up is just theory:
Front:
1 degree Camber
5mm droop
Blue springs
0 toe
40wt oil
#2 piston
rear sway bar (yellow)
Shock mount - outside
Camber link - inside
Rear
1.5 degree Camber
3mm droop
blue springs
2 degree toe in
40 wt oil
#2 piston
shock mount - outside
camber link - inside
Ride height, 5 mm front and rear.
Class - Stock Sedan
Motor - Monster Stock
Spur - 120
Pinion 36 and or a 37
Tires - Take Off's c22 or c27 [/B]
Hey Mike F, was this the setup you ran? How was the traction?
jackhammer74 is offline   Reply With Quote
Old 03-04-2003, 01:35 PM   #1229
Regional Moderator
That's the set up jackhammer74. The only thing that I did differently was add 1 black shock piston to each shock, internally. The ones that come with the 04R kit. I still have the white piston in place but needed a little less travel on the shock since I adjusted the droop settings from the manual
The car had a slight oversteer but I'm going to wait until it's actually warmer before I change anything. It was about 45 degrees and cloudy Sunday.
Old 03-04-2003, 02:10 PM   #1230
KINGZJ's Avatar
Mike I am going to assume you may know a little about the place where the TCS race is going to be held this summer. Can you tell me a little about the place and what kind of surface it is and so on. I will need to prepare a couple of cars for this race.
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 07:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 06:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 10:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 04:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 08:39 AM
