Old 12-05-2002, 10:56 PM   #901
PizzaDude's Avatar
Steevo,
Try to avoid lube just abouty as much as possible no matter what the manual says, in an open drivetrain car.
It allways attracts dirt and dust!!!
NEVER use it on pinion/spur.
NEVER use it on ball ends, dogbones, and try not use/minimize on mips/universals.
The wear and tear will be very high if you'ld do this.
Regards,
Pizza
PizzaDude is offline   Reply With Quote
Old 12-05-2002, 11:39 PM   #902
Steevo's Avatar
Thanks Pizza Dude,
I thought that was the case. I don't lube the other bits so there is no problem there. I just was unsure about the Spur/Pinion setup.
Steevo
Steevo is offline   Reply With Quote
Old 12-05-2002, 11:44 PM   #903
rough512's Avatar
Default Hey Steevo
Why not devise a cover for the spur/pinion gears? I'm thinking of building one from some thin lightweight plastic canisters such as those that contain (local) cotton buds.
rough512 is offline   Reply With Quote
Old 12-05-2002, 11:48 PM   #904
PizzaDude's Avatar
Rough,
WHY?
There is absolutely no real advantage to be gained by lubing the spur and pinion.
At least there are allways bigger disadvantages!
Pizza
Old 12-05-2002, 11:55 PM   #905
rough512's Avatar
Default PizzaDude
No, I dnt lube the Pinion/Spur gears myself.
I'm thinking the gear covers might save me some Spur gear changes. The local track I run in is really dusty and "pebble-y" sometimes.
Old 12-06-2002, 02:38 AM   #906
Steevo's Avatar
Hi Rough,
I intend to do some development early next year on a couple of items for my TA04.
I have recently been doing some work with Carbon fibre and I intend to make some covers for the front and rear diffs which I have already designed on Paper. Also on the cards are some alloy rear bulkheads and a few other Carbon Fibre bits and pieces. I have already made some carbon fibre battery hold downs to replace the standard plastic as well as a carbon fibre Spur gear Plate, and a flexible carbon fibre upper deck which is similar to the TA04Pro upper deck.
I have a lot on my plate until February so everything is on hold till then.
Steevo
Old 12-06-2002, 02:23 PM   #907
TRF-Powered's Avatar
Hi I got a quick favor that I need to ask all 04R owners
what are the turnbuckle sizes in the 04R ??? I need all of them. Thank you very much
TRF-Powered is offline   Reply With Quote
Old 12-06-2002, 02:32 PM   #908
psycho's Avatar
I'm not exactly sure, but the catalog lists the following tierods for the car.
53525 3X18
53526 3X23
53527 3X32
Guys, what's been your experience with the front belt? How long does it take before it stretches and the drivetrain is nice and free? I'm running stock and the car is a slug with the tight front belt.
psycho is offline   Reply With Quote
Old 12-06-2002, 02:53 PM   #909
linger's Avatar
psycho,
when I had my 04-R, I ran the belt tensioner really friggin tight (all the way down) for the first couple of battery packs. That stretches it out a little.
-Ling
linger is offline   Reply With Quote
Old 12-06-2002, 04:22 PM   #910
Default woooooooohooooooo!!!!!!
just received my new 2002 NSX ta04-r from stellamodels!!!!!!
oh yea!!!!!!!
it soo cool !!!!
it comes with the new carbon lightweight chassie with the holes for battery slots, flourine coated trf dampers.
any tips on building it?
this is the box:
sengming is offline   Reply With Quote
Old 12-06-2002, 04:23 PM   #911
this is the carbon light weight chassie with battery slots.
really coollll!!!!!
Old 12-06-2002, 04:23 PM   #912
psycho's Avatar
Haha! Stretch the front belt!
Old 12-06-2002, 05:40 PM   #913
rtypec's Avatar
Default Stretching Front Belt
Yup, Linger has a very good tip if you intend to run the car in stock racing. Temporarily install all the belt tensioners and run the car several times with a junk/practice 9Turn. When finished, remove all of the belt tensioners
rtypec is offline   Reply With Quote
Old 12-06-2002, 06:02 PM   #914
Flyer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Flyer
TRF-P
Check with Speedtech for the turnbuckle..
Flyer is offline   Reply With Quote
Old 12-06-2002, 07:06 PM   #915
Steevo's Avatar
Psycho,
After about 4 Packs and I noticed a significant decrease in belt tension. (I am running a 10X4 Though) The tensioner was set so it just touched the belt.
Steevo
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
