Old 09-21-2002, 12:31 PM   #751
Oh. The stock 48p spur that comes with the TA04S kit is an 88t.
coolrcdad is offline   Reply With Quote
Old 09-22-2002, 04:03 AM   #752
mulgar's Avatar
I have a question about the 'anti-wear grease'. Is it fine to use the standard ceramic grease in its place? If not are there any other alternatives to the anti-wear grease as I could not find any store that could supply or order this grease for me in my country. Thanx
mulgar is offline   Reply With Quote
Old 09-22-2002, 04:15 AM   #753
rccarracer's Avatar
Yeah the anti-wear grease is none existant here in Australia isn't it, but you best bet is to order it from Japan, or ask your lhs to give you another of the "portions" out of a kit they have dismantled.
I can get you some if you want, email me your address and I'll send a few in the mail....I work in hobby store.
rccarracer is offline   Reply With Quote
Old 09-23-2002, 07:37 PM   #754
black-knight's Avatar
R/C Tech Charter Subscriber
What's the best insert to use with Tamiya Type or B tires?
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 09-26-2002, 05:33 AM   #755
stratuskyo's Avatar
Default anyone....
i am a begainner can anyone e-mail me the setup sheet for technical track for tao-4 r pls...........
stratuskyo is offline   Reply With Quote
Old 09-26-2002, 05:39 AM   #756
stratuskyo's Avatar
Default ....
my e-mail address is kyo_heng@hotmail.com thanks.....help me thanks......
Old 09-26-2002, 05:40 AM   #757
stratuskyo's Avatar
Default .....
there is a under score in between kyo and heng.......thanks.....
Old 09-26-2002, 06:00 AM   #758
Alvin's Avatar
Ahem. Nice logo you got.
For TA04R, the stock setting out of the box is pretty good. At most, you might want to fine tune your droop so that it droops about 2mm front and rear. That's what I use.
The differences for me include:
Front: 2 piston, 50wt, blue roll bar, yellow spring, if you need more corner exit bite use C1 Front Upright on the right. Camber -1.
Rear:Inner, highest shock tower mounting position for your camber link. Stock on the rear hub. 2 piston, 50wt, yellow roll bar, yellow spring. Camber -1.5
Oh btw, I run double one way nearly exclusively. I'll be running 4wd on carpet this sunday though ;-)
If you run a hot modified, you will need to up the spring and oils to harder ones.
Alvin is offline   Reply With Quote
Old 09-27-2002, 06:42 AM   #759
lonestar1127's Avatar
hi everyone.....i have a tA04 PRo.....but can i use tA04r tub chassis to replace the original chassis?
lonestar1127 is offline   Reply With Quote
Old 09-27-2002, 06:56 AM   #760
Yes, the chassis should come with everything you will need, and will be a direct replacement......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-27-2002, 07:13 AM   #761
but u tried it b4?
Old 09-27-2002, 07:44 AM   #762
ijnek's Avatar
Send a message via ICQ to ijnek
i have the 04r with the tub chassis n i recently changed it to the carbon lower deck.should not b any problem.
ijnek is offline   Reply With Quote
Old 09-27-2002, 02:36 PM   #763
No but the fact that Tamiya sells it as an upgrade with instructions tells me that is what it is made for....LOL
Old 09-27-2002, 06:50 PM   #764
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
IMPACTPLAYR how has that new track in Hagerstown doing so far?
Old 09-28-2002, 06:52 AM   #765
Grand openning is this Saturday the 5th from 1-4 and hopefully racing will begn on The following Saturday. If you get a chance stop by I will be practicing on the 5th during the grand opening.
It's a little bumpy, but looks worse than it is, definately alot of fun to run on and racing should be a blast. The track is set a little loose because he expects alot of kids racing, but still challenging.
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
