Old 09-01-2002, 11:10 PM   #736
alucard's Avatar
Originally posted by DNQ
Does anyone know what manufacturers make aluminum steering knuckles and/or front hub carriers for the TA-04? I know Tamiya makes these parts for other models (TA-03 for one) but for some reason not for the TA-04.
Hi DNQ, Tamiya got TA-04 Alu steering set and Cross produce TA-04 front hub carrier.http://www.rc-cross.com/page/frame.html
alucard is offline   Reply With Quote
Old 09-02-2002, 09:12 AM   #737
DNQ
DNQ's Avatar
Thanks a lot. I'll be in Japan soon so hopefully I can pick some up at a local hobby shop.
DNQ is offline   Reply With Quote
Old 09-02-2002, 11:47 AM   #738
alucard's Avatar
Wah....going japan. Shiok scia........remember to buy more rare stuffs.
Old 09-16-2002, 02:05 AM   #739
hi every body
i was just wondering is there a graphite reinforced bulkhead made for the 04? cause it's time for me to replace the plastic ones on my 04 (holes maybe stripped) and i figured, why not upgrade?
thanks
mobilenemo is offline   Reply With Quote
Old 09-16-2002, 09:52 AM   #740
No graphite bulkhead but Tamiya does make a "reinforced" rear bulkhead set that includes a cool blue aluminum cross brace. Set also comes with a rear-belt tensioner/guide that sits inside the gear case.
coolrcdad is offline   Reply With Quote
Old 09-17-2002, 12:00 AM   #741
hey coolrcdad, d o you know what the part number is? thanks
Old 09-17-2002, 09:23 AM   #742
ijnek's Avatar
Send a message via ICQ to ijnek
any1 knows where can i can titanium turnbuckle shaft for the 04r?...
ijnek is offline   Reply With Quote
Old 09-17-2002, 02:44 PM   #743
probably mix and match from Lunsford or Associated?????
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-17-2002, 03:03 PM   #744
TRF-Powered's Avatar
Tamiya is coming out with their own Ti-turnbuckles.... if you do race at Tamiya races, you might want to wait a little and get that
TRF-Powered is offline   Reply With Quote
Old 09-17-2002, 03:33 PM   #745
You can wait for them to be released in the states and also pay a little more or, you can order from Japan.
53525 3x18mm Titanium Turnbucle Shaft $7.00
53526 3x23mm Titanium Turnbucle Shaft $7.80
53527 3x32mm Titanium Turnbucle Shaft $9.60
53528 3x35mm Titanium Turnbucle Shaft $10.40
Hiro's got them.
x414x is offline   Reply With Quote
Old 09-18-2002, 07:55 AM   #746
Mobilenemo: reinforced gear case part # 49203
I bought some of the Tamiya ti turnbuckles from Rainbow Ten in Japan, about $9 a set. Nice parts.
Old 09-20-2002, 01:12 PM   #747
SpeedTech's Avatar
Hi Guys,
Got a couple more TA04 hop-ups added to our website (Hardened layshaft, and 39mm light weight aluminum dogbone part)
Thanks, and I'll see you guys at the TCS nats next week
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 09-21-2002, 08:02 AM   #748
mulgar's Avatar
Hiya,
I have a relatively stupid question to ask regarding my TA04 which I hope someone can help me out with. I've been racing using 64 pitch gears and want to change over to 48 pitch. My question is that I don't know which combinations of spur and pinion gears will 'fit' in the ta04 (as i can't afford 'trial-and-error' way of finding out). I need something with a ratio of around 2.5 to start with, once i get one combo that fits i'm sure i can work out things from there.
Anyone using 48pitch gears on their ta04 should be able to answer this question pretty easily and I would be very grateful for an answer to save me some hassle 87)
mulgar is offline   Reply With Quote
Old 09-21-2002, 09:00 AM   #749
mulgar,
We use 48 pitch gears: 93 t spur and 27-30t pinions, depending on the motor. 96t spur will fit, too.
Old 09-21-2002, 09:15 AM   #750
mulgar's Avatar
thanx for the reply, but i need to gear it with a ratio of around 2.5, and those gears are around 3.5 (i think) as i'm still running a 540 at the moment and don't want to gear it too high as 540's have no guts 87)
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 07:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 06:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 10:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 04:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 08:39 AM
