Old 05-23-2002, 11:54 PM   #556
KiwiKid's Avatar
Default Re: Re: First real race and questions....
Are we going to see a Leafs' comeback?
Originally posted by Iso Octane
WHOA! That is one terribly frightening gear ratio!
Isn't it the rule to make the ratio numerically higher, with lower turn mods?
I have trouble with heat at 128/40 ratio (could be my problem) on a 12t.
Kiwikid: Quick look to my globe... ah... so that's where you are.
KiwiKid is offline   Reply With Quote
Old 05-24-2002, 07:42 AM   #557
Aurra Sing's Avatar
Corse-R - Try 48 pitch gears, they will last longer.
Aurra Sing is offline   Reply With Quote
Old 05-24-2002, 08:02 AM   #558
KINGZJ's Avatar
Send a message via AIM to KINGZJ
corse-r
use hpi gears they fit the tamiya hub perfect (metric I.D. of gear) and they are cheap. I prefer 64 pitch works better for me. Droop on ta04 really never did much for me I tuned with the camber links and played with the steering ackerman. You can ask impactplayer my car was way hooked up at the tcs race in hanover. I would install ball diffs that would be the single best thing you could do and I personally would go lower on the shock oil I run 40 all around with the yellow or white springs all around. also try a sway bar....
KINGZJ is offline   Reply With Quote
Old 05-24-2002, 07:21 PM   #559
Iso Octane's Avatar
I'll give them ratios a try Corse-R
Kiwikid: I'm sure the Leafs can come back, but confidence really hurt now, since they're down 3-1 in the series.
Iso Octane is offline   Reply With Quote
Old 05-25-2002, 12:59 PM   #560
Corse-R's Avatar
Default Rear uprights confussion!!!!!
Hi to all:
Can anybody explain me what's the difference between those three parts?
Item 50869: TA04 'E' parts. (Stock on TA04 chassis).
Item 53428: TA04 Hard rear uprights. (Stock on TRF414).
Item 53472: TA04 Toe-in rear uprights. (Stock on TRF414M).
I've heard that ones of those are 2mm toe-in and others were 1mm toe-in. Can anybody point me what are the 1mm and what are the 2mm ones?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-27-2002, 01:56 PM   #561
Corse-R's Avatar
Default Gear ratios and mesh table.
Hi to all.
From this weekend I'm constructing a table with the possible mesh ratios available for the TA04. Because some Pinion/Gear combinations are impossible due to the fact that the motor slides under the spur, can be wise to know in a shot what kind of ratios and combos are possible and not fighting with the car to mesh an almost impossible combo, like I needed to do last weekend (112/43) and ended filing the motor plate.
To do this. I'm working with my gear collection of 64p of spurs and pinions and I'm creating a table with those spurs: 112, 114, 116, 118, 120 & 128T and pinions from 38 to 47T (sorry, I don't have any spur between 120 and 128, so if anyone wants to check what combinations are possible can be great to add to this table).
Currently I'm working on this table, anyone interested on those when I finish it?.
Cheers,
Corse-R
Old 05-28-2002, 05:57 PM   #562
linger's Avatar
Default Re: Rear uprights confussion!!!!!
Originally posted by Corse-R
Hi to all:
The 50869 is 1 deg of rear toe
53428 is the same as 50869 but with the carbon reinforced material.
53472 is 2 deg rear toe with the carbon reinforced material
linger is offline   Reply With Quote
Old 05-29-2002, 12:41 AM   #563
Corse-R's Avatar
Default Re: Re: Rear uprights confussion!!!!!
Ok. Then what I need is this. Thankyou. I expect to calm a little the rear end of the car is way much squirrely.
Cheers,
Corse-R
Old 05-29-2002, 02:00 AM   #564
KiwiKid's Avatar
Sorry to see that the Leafs lost ... a very sad day.
Old 05-29-2002, 04:35 PM   #565
Iso Octane's Avatar
I'm actually quite relieved. All the Leaf hysteria and hype were really starting to piss me off. Plus, all those Leaf flags that people attach to their cars were most likely hurting their aerodynamic efficiency, and thereby increasing fuel consumption.
So ya, it's not so bad.
Old 05-29-2002, 06:48 PM   #566
KiwiKid's Avatar
Oh well, enough about the ice hockey. back to discussion about the TA-04R only. hehehe
Old 06-01-2002, 03:38 AM   #567
TRF_SPAIN's Avatar
corse-R quien eres?,si vienes a la copa la semana que viene,podemos intentar ver que le pasa al coche y como podemos solucionarlo!
Un saludo
Alvaro Villar
PD-Sorry for the spanish lesson guys! just trying to help a Tamiya racer on my area!
TRF_SPAIN is offline   Reply With Quote
Old 06-01-2002, 05:05 AM   #568
Corse-R's Avatar
Hi Alvaro:
For not breaking the laws on this forum, I'll answer partial on plain English. I'm Alfonso Correas and yes, I'll attend to the TCS race next weekend at Alcobendas.
El Navascues tambien se apunta a la categorķa de rallye. Va a estar 'mucho bien' esa carrera.
Saludos,
Alfonso Correas
Old 06-01-2002, 07:15 AM   #569
TRF_SPAIN's Avatar
Now i see why people here, say that if you need something "outside" u must contact with you guy, LOL, u speak a very nice english must be your "BritT" contacts )), yep i saw the rally inscription hehe, i think that he want to win like Jose Maria did LOL,i“m gonna race stock touring,i need to qualify and i donńt want to race again F1 until the next season in the TCS...i was really dissapointed with the last race result...
Well, i hope to Cu next weekend with that TA04R!! and u know, that i“m gonna give you any help that you need!
Cu!
Old 06-01-2002, 09:31 PM   #570
Iso Octane's Avatar
Default TT-01
Is Tamiya releasing a new chassis?
The TT-01 shown in the above pic at the Shizuoka Hobby Show, seems to be shaft driven, with a layout reminiscent of the TB series. Guessing it'll be release with the new (and kick-ass lookin') Integra R body, as show below:
But they say it's an Xpert Built car, which implies something dynamically low-end. So perhaps this is the replacement for the aging TL-01.
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 07:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 06:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 10:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 04:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 08:39 AM
