Old 05-02-2002, 09:19 PM   #496
I did a mod to my TA04 couple of days ago so i could fit in a 7/2 cause with motor heatsink you cant gear the car lower then a 128/30 so i had to file the holes of the mount so i could slide the motor in more.Now i can use right down to a 25T pinion.
Here is my current setup
Front
toe in = -0.5
camber = -1
springs = Tam white
oil = Team Losi 90W
shock pos = outer on arms and tower
camber link pos = upper,outer
tires - takeoff cs22 with med yok insert
oneway
Rear
toe in - 2 degree hub
camber = -1.5
springs = Tam Red
oil = losi 50
shock pos = outer on arm,2 from outside on tower
camber link = lower middle
tires = takeoff cs22 with med Yok insert
centre oneway
saddle chassis
this setup is for mid to high traction carpet .
Like to see other peoples setups for Modified.
CRAZY SPEED is offline   Reply With Quote
Old 05-05-2002, 10:48 AM   #497
Corse-R's Avatar
Hi guys:
Today I've run my 04-S (is box stock, except for the AL shocks and the optional springs). Is a very very docile car, but I need to shave some time compared with my laps done with my TC3.
This is my setup.
Front:
Al Shocks.
50wt oil
2 hole piston.
Blue spring.
Upper outer shock mounting hole
Lower inner shock mounting hole
Stock camber mounting holes
2 degree camber
0 degree toe-in
Rear gears diff with AW grease (to tighten up a little)
Sorex 28 with B medium insert (sorex too)
Rear:
Al Shocks.
50wt oil.
2 hole piston
Yellow spring
Upper inner shock mounting hole
Lower outer shock mounting hole
1 degree camber
Motor: 12x2 with a 120/44 ratio (about 5,8:1).
Any suggestions? my track is very large with high speed turns (awaiting the one-way pulley and sway bars).
Planning to run my local TCS (June, 9/10). I already ordered the motor heatsink plate to cool a little the motor (it really gets very hot). Any other necessary hopups that can be interesting to get?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-05-2002, 11:09 AM   #498
Alvin's Avatar
Corse-R,
Might I recommend the Racing Hub carriers, they improve low speed steering tremendously (6 degree of castor) but I'd guess you won't need it with a big track. Else it is a very major improvement, in the small tight tracks I jam at.
~Alvin
Alvin is offline   Reply With Quote
Old 05-07-2002, 01:20 PM   #499
SpeedTech's Avatar
Hi Guys,
Just want to let you guys know we are now stocking some Tamiya car kits, mainly TA04R. We will have TA04R parts online as well. I'm open to any suggestion as to what you guys what us to carry and see on the website. Thanks!
Steve Wang
Speed Tech RC
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 05-07-2002, 05:04 PM   #500
linger's Avatar
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Speed Tech RC
www.speedtechrc.com
Steve,
Unfortunately for shop owners, nothing on the Ta04 breaks. The plastic top pulley and the belts do wear out, but that's about it.
04-R owners might probably look for:
front and rear carbon fiber shock mounts
hard tuned spring set
Tamiya brand dish rims
lightweight outdrives
lightweight universals
front and center 1-ways
Tamiya tires for TCS
linger is offline   Reply With Quote
Old 05-07-2002, 05:18 PM   #501
Yeah, mainly hop-ups and the carbon tub for the 04!!!! MAN I broke one!!!! and ball studs!!! those Aluminum ones are prone to breakage!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-07-2002, 06:19 PM   #502
Alvin's Avatar
Also might want to carry 53479 Low Friction Suspension Pins (basically hinge pins), I tend to bend them if I use the Hard Reinforced Arms. So I'm back to the nice soft plastic arms
Also, the kingpins are prone to removing themselves, else erm basically I wear out the top pulleys, mostly and the steel outdrives
Old 05-07-2002, 10:06 PM   #503
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Default TA04 ss? ?
Hi guys! Has anyone of you seen a short version of Ta04r? Or is it called Ta04ss(super short). I heard its production will come out by end of June. It comes with a Toyota MRS body too. Im curious about it.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 05-07-2002, 10:48 PM   #504
rccarracer's Avatar
You know I've never broken one in my life, a friend has and I've worked out the only reason they break is if they are not screwed in all the way and not flush with the main piece, ie shock tower.
rccarracer is offline   Reply With Quote
Old 05-07-2002, 10:52 PM   #505
rccarracer's Avatar
Default Re: TA04 ss? ?
Yeah I saw that on the Tamiya English site's new release section.
Really I don't know why Tamiya want to bring out a short wheelbase version of the TA04S.
Oh, well I guess they did it with the 03, so they have to try it with the 04S.
Old 05-08-2002, 08:49 AM   #506
SpeedTech's Avatar
Hi Guys,
Thanks for your input. So mainly hop-up parts then is what guys are looking for? I'll keep that in mind when I bring in the parts.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 05-08-2002, 04:42 PM   #507
Aurra Sing's Avatar
Lightweight outdrives and aluminum pullies (center and ball diff) are a definately needed.
Aurra Sing is offline   Reply With Quote
Old 05-08-2002, 09:38 PM   #508
SpeedtechRC: Will you be carrying the tamiya B's?
JC
tiggersz is offline   Reply With Quote
Old 05-10-2002, 05:27 AM   #509
black-knight's Avatar
R/C Tech Charter Subscriber
Default kit differences?
I will be obtaining a TA-04 to run in TCS Australia. But i want to know what the differences in the kits are! If i purchase the TA-04R HKS Altezza kit; Does it come with all of the options that come with the Chassis only kit? I want the exact differences please! I believe that the molded carbon/graphite chassis comes in this kit? Does it have cutouts in the base for the cells to sit in nicely? Someone here in Oz has one like this and i want to know if it is a hop-up part, or maybe they cut the slots themselves?
Any info would be appreciated.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 05-10-2002, 05:39 AM   #510
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
