Old 02-25-2002, 04:27 AM   #361
Alvin's Avatar
Default Locking a centre one way
Dear All,
I have just bought a centre one way. Is there a way to lock it so it performs exactly like a locked layshaft? Drat I wish it used 2 one way bearings instead of one
Thanks.
~Alvin
Alvin is offline   Reply With Quote
Old 02-25-2002, 04:29 AM   #362
Alvin's Avatar
Default US Spec Carbon Chassis
Aurra,
if you happen to be around can you tell me if the US Carbon Spec chassis fits the TA04R precisely (no dremel etc)?
Because it seems I may have access to get a set. The person selling mentioned there was no need to run the metal centre pieces as the chassis is already very rigid. So now I'm like torn between buying the chassis VS buying more batteries. Thanks.
Regards,
Alvin
Old 02-25-2002, 06:19 AM   #363
Aurra Sing's Avatar
Alvin - The Saddle chassis fits perfectly with the TA04R (I used it on the TA04R in fact.) There's no problems with the belt being too tight, or anything. HOWEVER, you will need to find flat head screws and chassis posts for the front holes of the rear bulkhead. The chassis posts are critical.
Aurra Sing is offline   Reply With Quote
Old 02-26-2002, 05:31 AM   #364
Alvin's Avatar
Hi Aurra,
Thanks for the tip. Guess I will not be getting the carbon chassis soon - I doubt I can find the posts to support it in the centre.
Old 02-26-2002, 05:37 AM   #365
Alvin's Avatar
Default Minor Weight Loss Tip
Dear 04 racers,
Bought speedmind battery straps to replace the stock battery hold downs. The straps allow us to remove the 2 plastic hold downs, 4 body clips and the 4 screws mounted on the moulded chassis posts. Saves a bit of weight (Fully loaded, my 04 weights 1620g previously).
Some batteries are smaller sized and tend to bounce up and down, the strap eliminates the variable space found between the battery and the hold down, allowing it to hug the lower chassis very tightly.
Another plus point is that using the battery straps it kinda forces you to tighten up the straps - much lesser chance of forgetting to place the battery hold down before setting the car down on the track.
I did exactly that in my last race, and DNF'd my main by having the battery fly out. And damaged a good, abeit unmatched battery.
HTHs.
Regards,
Alvin
Old 02-27-2002, 01:51 AM   #366
Send a message via ICQ to melvin
Default Re: Minor Weight Loss Tip
Alvin,
I am from Singapore too but have never met you before. Can you tell me where you got the batt strap??
melvin
Originally posted by Alvin
Dear 04 racers,
HTHs.
Regards,
Alvin
melvin is offline   Reply With Quote
Old 02-27-2002, 03:42 AM   #367
F&K
F&K's Avatar
Hey guys,
I am new in TA04. Can anybody tell me the different between the TA04 Pro & TA04R version?. Are they interchangeable? Handling wise, which is better? Can't decide which to get
F&K is offline   Reply With Quote
Old 02-27-2002, 06:13 AM   #368
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
The 04 and the 04R are from the same chassis family...Biggest difference - the 04R comes with pretty much all the needed/improvement hop-ups available from tamiya
the 04R comes with:
a carbon fiber tub chassis (04 comes with a cruddy plastic chassis)
CVD-like universals front and rear (04 come with dog bones)
a grgaphite upper deck (04 comes with a plastic upper deck)
full bearings (04 bearings varies from drive-train to none to most)
aluminum motor heat sink (04 come with a alumium non-finned heat sink)
turnbuckles all over (04 no turnbuckles)
ball diff front and rear (again, depending on which 04 you bought gear diff or possible ball diffs)
5 deg front hub carries (04 has 10 deg carriers)
2 deg rear toe-in hub carrier (04 comes with 0 deg)
droop screws (not on 04 chassis)
threaded TRF shock bodies (04 plastic shock bodies)
yellow springs and sway bars (04 - either silver or gold springs and no sway bars)
the 04R is a better deal for the money...Much better deal than the pro kit
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-27-2002, 06:14 AM   #369
Alvin's Avatar
Hi Melvin,
I believe we have met in 27/2's race, you were pitting beside Kasey right? Not formally introduced yet
Anyhow, those were speedmind stuff, I got from Swan. Price no idea, got a bunch of stuff from there too...
Old 02-27-2002, 06:51 AM   #370
F&K- go with the 04-R, for $30 more you get all the goodies and that sweet carbon fibre looking alteeza body....well worth the money.
BTW: K forgot to mention that the 04 comes with 8 deg. caster blocks and the 04-r has 5 deg. units and torque rods to stiffen up the front end.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 02-27-2002, 07:29 AM   #371
F&K
F&K's Avatar
Hey guys,
Tks for the reply! But if I am not wrong, TA04 Pro had came out with a blue edition type with some option blue aluminum parts. The price is also quite attractive. Handling wise, what do you guys think is better!
Old 02-27-2002, 07:40 AM   #372
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Get the ta04r, blue doesn't get you very far at the last tcs race in brookfield WI with over 160 entries (new tcs record) the top 2 cars in gt2 were brand new box stock ta04r kits I know I drove one of them the top car in gt1 was also the same ta04r that was run in gt2 same car same setup box stock wooped everyone else's pro's now maybe you will have an idea of the car potential
KINGZJ is offline   Reply With Quote
Old 02-27-2002, 01:11 PM   #373
TRF-Powered's Avatar
Alvin,
I read your past post and see you bought some tamiya turnbuckles.
Do you know the part number for the turnbuckles that are 23mm??
is the turnbuckles that are 18mm long called "Ta04 turnbuckle upper arm set"???
Please reply, Thanks
TRF-Powered is offline   Reply With Quote
Old 02-27-2002, 01:13 PM   #374
KINGZJ's Avatar
does anyone have the part number for the lightweight diff halves
thanks
Jesse
Old 02-27-2002, 02:32 PM   #375
linger's Avatar
thanks
Jesse
part number 53480
linger is offline   Reply With Quote
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
