Old 02-12-2002, 06:08 AM   #346
KINGZJ's Avatar
Send a message via AIM to KINGZJ
please explain the chassis in the freezer is this something that needs to be done with tub tao4r chassis?????
p.s. still waiting for part numbers!!!!
KINGZJ is offline   Reply With Quote
Old 02-12-2002, 06:40 AM   #347
Fangio's Avatar
I don't know exaxlty what it does but it flattens out the chassis. I don't see the part number on the instruction sheet for the chassis. Sorry.
Fangio is offline   Reply With Quote
Old 02-12-2002, 10:38 AM   #348
linger's Avatar
So how do I get this new updated chassis?
I have a Ta04-R but never sent in the original chassis.
linger is offline   Reply With Quote
Old 02-12-2002, 10:40 AM   #349
linger's Avatar
Originally posted by KINGZJ
anybody able to find those part numbers for the tire,rim,insert package for type a and b's
thanks
jesse
jesse
The rim/firm insert/Type B tire set is part number 534128
Sorry, i do not have the info for the Type A Tire set
Old 02-12-2002, 12:30 PM   #350
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I would contact Tamiya Customer Service and ask them...I did it almost immediately after I got the car and had to wait for what seemed like forever (4 months) to get the new chassis back...
k_bojar is offline   Reply With Quote
Old 02-17-2002, 05:27 AM   #351
KINGZJ's Avatar
thanks for the tire info.
I have a couple questions!!!!
What is the spring rate or pound of spring for the Yellow springs that come with the tao4r??????
Are springs other than tamiya legal for tcs racing and if so which ones work the best for carpet???
Does anyone have the part number for lightened outdrives
thanks in advance
Jesse
Old 02-17-2002, 07:35 AM   #352
superk's Avatar
Default Help on setup the car! and finding parts
I have some trouble with the car!! I did every thing by the book and still...the car act really strange! Every time I turn just a little the car keep spin out and no rear traktion at all!! (FOAM TIRE) and when I put the rubber tieres in it seem like I have wayyy too much push..and the car will not turn! Here is what my setup like
Shock oil 40wt front and 30wt rear
Camber 1degrees front and 2 degrees rear.
Droop is arund 5.
Toe one 0 front and 2 rear.
What seem to be the problem? is it the tires? I run the car on carpet race.
superk is offline   Reply With Quote
Old 02-17-2002, 01:15 PM   #353
rccarracer's Avatar
From what I can see, that is just to much droop for carpet, droop should be 1 or even 0 for carpet.
rccarracer is offline   Reply With Quote
Old 02-17-2002, 05:25 PM   #354
Anyone know the spring ratings of the hard tuned spring set? I'd like to know, so I can get the correct aftermaket springs to use in conjunction with the tamiya springs. Thanks.
Potato is offline   Reply With Quote
Old 02-17-2002, 05:36 PM   #355
badboy's Avatar
Trader Rating: 14 (100%+)
TRF414 LOWER CHASIS
Guys,
Can I use the TRF414M lower chasis for my TRF414? I'm running on stick packs and the only way I can put in this my 414 is by using glass tapes. I noticed that the 414M has a provision for J parts (stick pack battery holder).
Thanks!!!
slow is fast . . .
badboy is offline   Reply With Quote
Old 02-20-2002, 06:51 AM   #356
I got my new 04-R chassis and it is soooo sweeeeeet!!!!!! God this thing is beautiful!!! TCS here I come!!!!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 02-20-2002, 02:28 PM   #357
k_bojar's Avatar
HEHEHE...That was pretty much the same expression that I had when I FINALLY received mine
Gotta love those counter-sunk screws and batter slots...only bad comment I have for both chassis is that if you direct solder your batteries you can use the battery hold downs Oh well, I guess I'll just be lighter and faster without them
Impact - which TCS are you planning on going to?? I'm definitely headed to the RCO race and most likely the race down in Laurel...Do you know how registrations work for the TCS races??? I cant find any info nor get an answer from RCO
Bodies By Bean | Team Belly
Old 02-20-2002, 03:19 PM   #358
linger's Avatar
I need more on-power steering on my TA04-R.
Hello everyone,
I'm having problems getting enough on-power steering from my 04-R on a high traction indoor asphalt track. Off-power, the steering is perfect. My lap times are consistenly .1-.2 sec slower compared to my Tc3 using modified motors. Any suggestions?
Currently, I'm running white springs front and rear, front red swaybar, yellow rear swaybar, front 1-way. Everything else is standard 04-R stuff.
Old 02-20-2002, 07:18 PM   #359
I will be at the TCS at RCO, and maybe Laurel too.
Call 1-800-TAMIYA-A and choose the option to enter for a TCS race.
Old 02-20-2002, 08:49 PM   #360
k_bojar's Avatar
Thanks...Guess I know what I'll be doing at work tomorrow
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
