Old 06-13-2006, 09:21 PM   #1936
racenut's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rcnewb2004
I still have my tao4-trf and still love the car... just worried to crash it... since part support is becoming difficult and expensive
Finally, a good hearted Tao4 lover posted again....
Some parts of Tao4 and Tao5 are identical.... like arms, hubs etc. We still have lots of parts for tao4 here in the philippines..
racenut is offline   Reply With Quote
Old 06-13-2006, 09:22 PM   #1937
racenut's Avatar
Originally Posted by rccardr
They all sem to have migrated over to the TA05 thread. Sad...these are such great cars
I have both Tao4 and Tao5, i always ran my tao4. I like the kit very much...
Old 06-13-2006, 10:40 PM   #1938
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
damn strong too
Yo!
KoE is offline   Reply With Quote
Old 06-14-2006, 12:51 AM   #1939
racenut's Avatar
Im with you!!!
Old 06-14-2006, 12:52 AM   #1940
racenut's Avatar
How to fit side by side batts to the Carbon fiber chasis??? Any good ideas???
Old 06-14-2006, 05:29 AM   #1941
Aluma's Avatar
I'm waiting to get a lipo 4800 pack to use in the ta04r. still cant get the side by sides in there. :P What pinion y'all usually use with the 128T spur for stock motors? I dont remember if the Tamiya uses normal 64 pitch or does it also use pitch metric for those too? I dont have any 64pitch pinions so I have to order that too.
Aluma is offline   Reply With Quote
Old 06-14-2006, 04:57 PM   #1942
racenut's Avatar
yeah, its kinda hard fiting the side by side to tao4. I use 23t motor. My spur gear is 120t and 45t for the pinion. Im having a good acceleration and top speed, also a longer run time from my gp3300....
Old 06-14-2006, 07:16 PM   #1943
Only way is to dremel it and finish it off with file.
See pic and check where the arrows points, that's where I file it down.
Just took a bit of my time and tested my patience
Edgarski is offline   Reply With Quote
Old 06-14-2006, 07:30 PM   #1944
I'm selling some of my TA04R B/New parts. Selling it cheap lower than current RRP. If you're interested just PM me but the only prob is Im here in Sydney so postage is ??? ..but considering these are small and plastic items there's a chance postage is not expensive at all.
QUOTE=rcnewb2004]I still have my tao4-trf and still love the car... just worried to crash it... since part support is becoming difficult and expensive[/QUOTE]
Old 06-14-2006, 09:31 PM   #1945
racenut's Avatar
And my gp3300 with battery bar and wire will fit??? that what i did with my previous tao4 but now battery wires interfere..
Old 06-14-2006, 10:20 PM   #1946
it should work well if you remove your wires.. and solder on an L-shaped batt bar and use bullet connectors
skamolly is offline   Reply With Quote
Old 06-15-2006, 12:31 AM   #1947
racenut's Avatar
Is that what you did??? but i use deans plug in all of my batts is there a way i can retain my deans plug instead of bullet connector???
Old 06-15-2006, 01:33 AM   #1948
I used dean plugs too before.. flatten the end of the wire before you tin it with solder and solder to your battery, in that way the soldered part is not that bulky and it will still slide inside...now with regards to the wires, what I did was I made the red(+) long enough to reach the negative (-) terminal.. and than the black wire is very short like 1.5 inch long only..in this way you will only manage the red wire to fit with out touching anything like the belt... obviously your ESC dean plug will sit on th side where your batt's negative side is... this setup worked with my TA04R with no probs. I wish I still have old pics of my TA04R for you to see.
Old 06-15-2006, 07:23 PM   #1949
KoE
KoE's Avatar
i removed the battery holder and used tape. not tcs legal tho
Yo!
Old 06-15-2006, 09:11 PM   #1950
racenut's Avatar
Thanks... i will try it tonight, oh...your using double deck chasis right???
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
