Old 09-26-2005, 06:11 PM   #1861
Send a message via ICQ to rcnewb2004
what does wd-ing the belt do to it?
rcnewb2004 is offline   Reply With Quote
Old 09-27-2005, 04:20 AM   #1862
rccardr's Avatar
Makes the belt and fibers softer, more elastic & therefore easier to stetch without damaging the tooth profile.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 09-27-2005, 10:56 AM   #1863
SMcpot's Avatar
Trader Rating: 22 (100%+)
Hey guys....quick question.....
Does the reversible suspension set come with aluminum suspension blocks and universals?
EDIT: nevermind....doesn't come with al. blocks, comes with lt. rear universals
Anyone gonna run their 04 in next year's TCS?
SMcpot is offline   Reply With Quote
Old 11-04-2005, 04:28 PM   #1864
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Default help with side by side pack
i have ta04 and the carbon reinforced(the one that comes to 04-r tuned chassis) lower deck.
how can i fit it with the side by side packs??
or
is there a way that i can fit the side by side to the carbon fiber chassis
need reply.... tnx
nikkiesteban is offline   Reply With Quote
Old 11-04-2005, 04:39 PM   #1865
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
nope...I would tell you that you might find yourself a bit off pace running the 04 against the 05
madjack is offline   Reply With Quote
Old 11-06-2005, 02:49 AM   #1866
r0adrunn3r's Avatar
Send a message via MSN to r0adrunn3r
Default Side by Side packs on a TA04R
Running side by side packs is a tight squeeze on the 04. I had to cut down the insides of the battery support post so that the pack could fit.
As you can see from the pictures below that you can fit a side by side pack with corally tube connectors fitted. The trick to insert and remove the pack is to push in it and push it out. If you pull on the pack the battery bars will bend
or
need reply.... tnx
Xray
Losi
www.hillsoffroadrc.com
r0adrunn3r is offline   Reply With Quote
Old 11-06-2005, 09:31 PM   #1867
Sushi Man's Avatar
Send a message via AIM to Sushi Man
well first of all I love this car... its great, i personaly think a TA-04 r is a way better car than a TA-05 stock.
few flaws i have noticed, you cant adjust the rear or front belt stiffness like the TA-05 and other belt bulkhead designs, battery is hard to deal with becuase it is not made to fit side by side packs, I took the plastic things out, and the battery in in, doesnt come out but is wobaly. Thats only what i think about, i actually just replace the belts if i need to, I only really car about the batt.
Good things, easy changing of spur and pinions, un like TA-05, easy maintence to the pully, you can get a double grahite chassis. Comes with the 64 pitch gears stock, TA-05 comes with like the weird tamiya gears...
This car is sweet
i ripped in GT2
Sushi Man is offline   Reply With Quote
Old 11-07-2005, 04:06 AM   #1868
Herc Driver's Avatar
I agree...got rid of the 05...keeping the 04!
I dont care if Im a little off the pace...car works and is easy to drive and work on. Ill bet it stays on pace enough. Possibly when the 05R is released Ill change my tune...but had an 05, kept the 04 what does that say?
Herc Driver is offline   Reply With Quote
Old 11-07-2005, 06:50 AM   #1869
madjack's Avatar
Regarding pace the the 04...don't get me wrong I loved my 04R with the LW arms, but the reality was in testing at the TCS Nationals last year my 04R was .9 slower per lap than my 05. It was time to put my my 04R out to pasture IMO.
Old 11-19-2005, 09:40 AM   #1870
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
I am going to be racing in the TCS race next year, and I am wondering about what options are suggested to get for the TA-04. I am getting the Tuned Chassis Kit, and I am for sure going to be running the reversible suspension. What size swing shaft is used on the car with the reversible suspension. I am so hyped about this car, also, are the diffs interchangable from front to rear? All suggestions are greatly appreciated.
tc3stocker is offline   Reply With Quote
Old 11-19-2005, 10:08 AM   #1871
Sushi Man's Avatar
ta-04 ARE VEry fast, mine is underweight!!!IT at around 1440 grams!!!!! crazy.
Im not sure if the diffs are interchangeable.. becuase i run a one way.
Old 11-19-2005, 10:10 AM   #1872
tc3stocker's Avatar
I need a good set-up with gearing and all, where can I find one?
Old 11-19-2005, 11:04 AM   #1873
or
need reply.... tnx
If you want to use side by side batts, you have to assemble your battery packs to be able to fit those offroad 2wd buggy and trucks. they would fit perfectly in your 04.
plus put on the ssg battery holders, do some work and they're perfect...just my .02cents
1-2-3...G0!!! is offline   Reply With Quote
Old 11-19-2005, 07:05 PM   #1874
rccardr's Avatar
Diffs are interchangeable front to rear. Everything else you need is on your car already. I'd suggest you hold off on the reversible suspension until you've gone as fast as you can with the stock arms. And then buy a center and front one-way first and learn how to drive it fast with that. If you're running the Memphis TCS, that's what I've won with there the last three years in a row.
Later
Doc
I've never lost.
Old 11-20-2005, 09:51 PM   #1875
What is the part number of the battery support/holder please?
Edgarski is offline   Reply With Quote
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
