Old 11-30-2003, 02:08 PM   #1696
ShadowAu's Avatar
Does anyone know where I can get alloy or Titanium screws (perferably a kit) for a TA04R???
Has anyone used the Integy/Eagle Chassis? Rear Arm mounts?
Is there any weight benifit of using alloy bits and peices ?
I am trying to upgrade My car for 2004 so I can be a bit more competitive and dropping a bit of weight of the chassis and adding a bit more tuneability is where I am looking... I also want a bit more flexibilty in battery mounting
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is online now   Reply With Quote
Old 12-01-2003, 06:31 AM   #1697
lem2's Avatar
Default Upgrade for 2004
I would rather use the Aluminum Arm mounts by Tamiya, its much better since you have 2 choices for the rear. They are great on my TAO4-R. The front Alm. Susp. Blocks does not offer any change or advantage in set up but looks cool!!!!!! If you have a little to spare, the SQUARE rear cariers and knuckle arms for the TBevo3 are great for the O4-R and are a direct fit. YOu can achieve 0-3degrees of toe in in the rear with that Option.
For the Ti Screws- Stick with Tamiya Ti Screws, I did! Although any other Ti Screws will do, Its Just to bad that Tamiya does not have a screw kit. A little more on the pocket to get the Tamiya Ti Screws for the Car.
And ofcourse-Ti TurnBuckles, either from Tamiya or Lunsford
Also, the SSG shock tower and upper deck is also a good upgrade for 2004. You just have to change to shorter springs, captured ball ends is also a good choice.
PS: of course alm is a little heavy
TIP: if you are going to get the SSG upper deck use it on top of the regular Carbon upper deck to make the chassis stiffer!
Glad to know they are still a few who is sticking withthe O4-R
Peace and Happy Racing!!
SQUARE offers a Ti Screw kit for the TAO4-R www.rc-square.com
and you can order them at www.rainbowten.co.jp I got most of my stuff from there
lem2 is offline   Reply With Quote
Old 12-01-2003, 06:38 AM   #1698
lem2's Avatar
Originally posted by PizzaDude
Does anyone know if the damperstays and suspension blocks from the Evo3 do fit on a TA04?
Also what's the difference in setup option, between the Ta04TRF and TA04R.
Iow what doe the suspension blocjk offer for tune-ability?
The TRF Suspension Blocks offers additional .5 and 1 degree of toe in. Together with the SQUARE rear cariers for the TBevo3, you can achieve a total of 3 degrees of toe in for the rear.
Basically the TRF version has different shock mounting positions and the alum susp. blocks + flourine coated shocks
Old 12-01-2003, 08:25 AM   #1699
lem2's Avatar
Default question
Can the sway bar holder which is on top of the upper deck, be purchased separately??
Old 12-03-2003, 08:03 PM   #1700
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default Re: question
No.! I think you can purchase a TA04-TRF Front Stabilizer set. I do have a few friends who did it on there own. I think it just needs some creativity.
Hey everyone. Lots of TA04 option parts for sale at good prices. http://www.rctech.net/forum/showthre...850#post616850
Izzy
izzyracer is offline   Reply With Quote
Old 05-17-2004, 04:04 AM   #1701
lem2's Avatar
Default rtypec
Thanks for finding it for me!
TA04 - R/S/Pro/SS/Tuned/TRF . . . .
Hi guys!! There are the 414's and the 415's now th Evo4, I know it's an old car but it's the one car that I would not sell from my many kits.
I was looking thru the pages and could not find the TA04 Thread, there were many other questions realted to this chassis. SO I thought I'd make a new thread and keep it permanent!
I just finished rebuilding mine! Woohoooooooo!!!!
Hope there are still a lot of Hobbyist using the chassis!!
Peace and Happy Racing!!!!
Lemuel Pia
Manila, Philippines
Old 05-19-2004, 01:24 PM   #1702
jackhammer74's Avatar
What servo saver do most of you guys use? I've been using a Kimbrough with pretty decent results, but I just upgraded from a JR to a better Futaba servo and I was wondering if I should stick with Kimbrough or if there is something better outhere.
By the way I know this thread is not as popular as it used to be, but the TA04 still rules, just last week I was pleased to lay the smack down to several TC3s. There's fancier, better cars outhere, but I still love my 04.
jackhammer74 is offline   Reply With Quote
Old 05-25-2004, 03:43 PM   #1703
Hello? Anybody outhere?
Old 05-25-2004, 04:54 PM   #1704
rtypec's Avatar
I use an Xray servo horn. Direct link baby. The material in the xray horn is soft enough to strip before the servo gears in a huge accident. I've been running them for the last year and have only stripped one arm running Futaba S9550 servos. Of course, if you are accident prone, a Kimbrough servo saver will work just fine.
rtypec is offline   Reply With Quote
Old 05-25-2004, 05:03 PM   #1705
lem2's Avatar
Default i agree
the 04 still kicks some butt! the thread is not that popular anymore,because the car is so easy to tune that no oneis asking anymore!
I also use a Fut 9550, with the tamiya servo saver. pretty good so far major crashes and the servo, servo saver is still okay!
Old 05-26-2004, 09:52 AM   #1706
Thanks guys I switched to the Futaba S3305 (great servo by the way). I'm not a frequent crasher but, better safe than sorry, I guess. I think I'll stick with the Kimbrough.
Old 05-26-2004, 11:00 AM   #1707
Baluga's Avatar
Nice avatar. Too bad they're not performing very well right now.
Baluga is offline   Reply With Quote
Old 05-26-2004, 05:31 PM   #1708
Thanks Baluga, hopefully they'll find their pace soon.
Old 07-08-2004, 09:49 PM   #1709
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default 414 converted to tub chassis
Can I convert a 414 to a gt2 legal car..ie swap out lower graphite chassis for tub?
It looks like it would be cheaper to do this than upgrade a ta04r/trf.
Jamie
J.Gonzalez is offline   Reply With Quote
Old 07-08-2004, 09:57 PM   #1710
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Default Re: 414 converted to tub chassis
Jamie
To my knowledge, there is no tub chassis for the 414 series of cars. the mounts on the TA04 chassis are different for the bulkheads. I think your better off buying a TRF or 04R....
RCBuddha is offline   Reply With Quote
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 06:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 05:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 09:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 03:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 07:39 AM
