Old 11-03-2003, 02:17 PM   #1666
hawker's Avatar
Just a reminder that my TA04 TRF is still up for sale, few scratches on the chassis from racing on asphaly but other than that perfect condition, well looked after $300AUD
hawker is offline   Reply With Quote
Old 11-14-2003, 02:31 PM   #1667
Default Wheels Offset
It seems that most of the TA04 kits (SS, R, TRF, S) come with 2mm offset wheels. Does that mean I will have problems running 0 offset wheels? Or do I need to use wheel spacers in order to run 0 offset wheels?
Having no luck selling my TA04-TRF kit, I am thinking about converting it to TA04-SS. Bought it with the intention of running the Audi-TT body but somehow Tamiya has not released the body separately. Any help will be appreciated.
Thanks.
Supra66 is offline   Reply With Quote
Old 11-14-2003, 03:33 PM   #1668
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default Re: Wheels Offset
Thanks.
The car will be fine with the 0 offset wheels. It won't cause any rubbing as long as you use the right hex hubs (6mm) or the 4 mm with the red spacers. Without the spacers it will be very close.
With the SS you will get lots of steeriing but will be more twitchy compared to the standard TA04 setup.
Izzy
izzyracer is offline   Reply With Quote
Old 11-16-2003, 07:51 PM   #1669
AgentSmith's Avatar
Default How to reduce free play of front wheels?
Hello folks
I see my 04 has quite abit of freeplay in the front wheels because of the "looseness" in the ball caps of the steering servo linkages. How can I reduce it?
AgentSmith is offline   Reply With Quote
Old 11-16-2003, 08:47 PM   #1670
psycho's Avatar
Default Re: How to reduce free play of front wheels?
Slip an orange o-ring over the ball before snapping the ballcup on. That will reduce the slop and not bind up the suspension movement much as long as you use the orange o-rings.
psycho is offline   Reply With Quote
Old 11-16-2003, 09:48 PM   #1671
AgentSmith's Avatar
Default Re: Re: How to reduce free play of front wheels?
I've come across black o-rings that you stuff between the diff gear and dog bones...
But orange o-rings? What are those?
Old 11-17-2003, 08:34 AM   #1672
rtypec's Avatar
Pick up a set of the low friction "gray" ball cups. They "snap" on harder and reduce play by a bit. Not only that but the seem to be made of a stiffer plastic. Give it a shot, they're only like 2-3 bucks a set.
rtypec is offline   Reply With Quote
Old 11-17-2003, 10:51 AM   #1673
psycho's Avatar
The orange o-rings are very soft. They come with many Tamiya kits for use in the shocks. If you don't have any, your lhs should sell them. I know Associated packages them, so your lhs should have teh Associated ones.
Old 11-17-2003, 11:10 AM   #1674
T-man
Guest
Posts: n/a
Thumbs up Audi TT body
Supra,
Take a look at your email regarding Audi TT body.
T-man
Old 11-17-2003, 12:37 PM   #1675
Baluga's Avatar
Default Need feedback
Everytime my TA04 gets a "very" minor crash, the car won't run straight after the incident. Need to readjust my radio subtrim to get the car go straight again. Is there anything I should do to prevent it? Do you think installing a aluminum servo stay will help? Thnx...
Baluga is offline   Reply With Quote
Old 11-17-2003, 01:38 PM   #1676
T-man
Guest
Posts: n/a
This can mean 2 things. One: the threading of the ball cups is shot to h....... So replace them with 53601 5mm Ball Adjusters. These are better than the standard versions.
Two : Your servo gets a bump on the head and it will be out of line. Will correct itself after another 'hit'.....mostly There is no need to replace the servosaver.
But number one is most common.
Old 11-17-2003, 01:42 PM   #1677
T-man:
Got your mail. Thanks for the part numbers. I called up Tamiya USA and they do have them in stock. Body, wing and decal come out to around $40. I think I am going to wait for a good deal on the Audi TT kit to get both bodies.
Anyone runs an Audi TT body? Do you feel a difference running the TT and the MR-S body?
Old 11-17-2003, 02:32 PM   #1678
ShadowAu's Avatar
Default Stripped pulleys
Hey there
I am wondering if anyone else has had problems with stripped centre pulleys and/or stripped front belts after fitting a front one-way diff in a 04R????
I fitted one just prior to the state titles here, and while it made the car MAJORILY quicker I have also now stripped 3 centre pulleys and two front belts in quick succession... resulting in only running 2 rounds of qualifying before lack of parts forced an early end to my weekend
I have checked all the obvious things and can't see a reason... the only thing I can come up with is that the plastic pulleys are just not up to running modifieds with the one-way fitted... but I can't find anywhere selling alloy versions (I am sure I've seen them somewhere)
any help?
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 11-17-2003, 02:40 PM   #1679
T-man
Guest
Posts: n/a
Hi There, here you go:
53462 : TA04 Alu Diff Pulley
53489 : TA04 Alu Center One Way Pulley (15T)
53474 : TA04 Alu Center Pulley (15T)
53510 : TA04 Hard Center Pulley SHaft
Use the last 3 part in combination and the first part as a replacement for the plastic diff pulley..... problem solved. Try Towerhobbies for purchase (for example).
If you need to see pictures etc go to www.tamiya.nl click tamiya logo go to Spare parts & hopups and see.... a list of the tuningstuff for the different chassis.
T
Old 11-17-2003, 02:48 PM   #1680
T-man
Guest
Posts: n/a
just a test sorry!
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 07:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 06:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 10:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 04:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 08:39 AM
