Old 07-19-2003, 09:25 AM   #1531
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Post TA04 Drive train
Originally posted by Rick Draper
Has anyone got any tips for building a TA04? I have a few tricks but just wanted to see what you in the US do to yours? Dan and Peter you must both have some hints and tricks to free the drive train up? Thanks Rick
Rick,
As Dan had stated bearings and belts (batteries of course) is the key in the North American GT3 & GT2 classes. Because the motors can be under powered in these classes you don't need to worry about the belts skipping.
I generally cook the bearings in an Integy cleaning box for about 4 hours (if new) and run VERY light oil... nearly dry.
The belts can give your a couple of choices. I opt for the low friction hop-up set. I soak them in WD40 for several days to help free them up. Or you can run old belts, they seem to work well also.
When tightening the top deck try to shorten the overall lenght of the upper chassis...if that makes sense. It will provide you with a front belt that is more loose.
Beyond that not much else can be done. I run my GT3 car with one-way diffs and pulleys.
I hope this helps you out.
Good hunting
John
madjack is offline   Reply With Quote
Old 07-19-2003, 01:30 PM   #1532
Thanks for the tips everyone i will try them on my TRF when it arrives this week hopefully. Rick
Rick Draper is offline   Reply With Quote
Old 07-20-2003, 03:17 AM   #1533
Does anyone here use side by side packs on their Ta04-R (tub chassis) ? Is this even possible?
I'm keen on picking one up so I can add a Tamiya belt car to my collection.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 07-20-2003, 04:43 AM   #1534
I use side by side packs in my car and you just need to position your connectors differently to get the batterys to sit correctly. Rick
Old 07-20-2003, 07:19 AM   #1535
lem2's Avatar
Default question
what degrees does the stock rear suspension mount for the
TA04-R have?
Just want to know before Iget the alum. ones. Thanks!!!
lem2 is offline   Reply With Quote
Old 07-20-2003, 07:21 AM   #1536
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: question
TA04-R have?
0 deg mounts.....it comes with 2 deg rear hubs to give you the toe in.
dtm is offline   Reply With Quote
Old 07-20-2003, 07:26 AM   #1537
lem2's Avatar
Default Re: Re: question
Thanks!!! Then I should get the aluminum ones to make it 3 degrees at the rear!!!! Thanks again!!!!!!
One more thing. What advantage will I get if I also use the alum. front suspension mounts?? TIA!!!
Old 07-20-2003, 07:30 AM   #1538
dtm
dtm's Avatar
Default Re: Re: Re: question
It will look pretty and match the rear ones that you just bought!
Old 07-21-2003, 09:28 PM   #1539
gcooper's Avatar
Default Belt Question
Have any of you guys played guitar with your front belt?
I just got a new bottom chassis and it does seem awfully tight. The belt is well broken in what have you done to resolve this?
Coop
gcooper is offline   Reply With Quote
Old 07-22-2003, 02:47 AM   #1540
Will the new alloy suspension arm blocks fit on a ta04r tub chassis?
Old 07-22-2003, 02:50 AM   #1541
ScottyP's Avatar
Default Front belt too tight
Coop,
I can play a mean tune on my TA04 TRF!
Seriously, this was a BIG letdown with the car. The belt is way too tight for decent acceleration or efficiency.
I tried to resolve the problem by shaving the top plate and compressing the chassis. Now all I have is a seriously tweaked car!
I'll be reverting back to the carbon tub chassis and an old belt from my TA04-R.
Scotty P
ScottyP is offline   Reply With Quote
Old 07-22-2003, 03:07 AM   #1542
lem2's Avatar
yep its a perfect fit!!! Just installed mine (front n Rear)
slop is gone!! and you can do 3.5 degrees of toe in the rear.
Old 07-22-2003, 05:20 PM   #1543
hobbipro's Avatar
Trader Rating: 21 (100%+)
I really wish someone could explain why the 04 series has really tight front belts. This is my 3rd 04 kit (04-Pro,04R,04-TRF) and all were tight as could possibly be. The 414M2 is the exact opposite, nice and loose. Tamiya must know why there making them this way, but doesnt make sense to me.
hobbipro is offline   Reply With Quote
Old 07-22-2003, 06:30 PM   #1544
psycho's Avatar
It could be deliberate to try to reduce the performance advantage of the 04 in the GT2 and GT3 classes over other tub chassis cars.
psycho is offline   Reply With Quote
Old 07-22-2003, 06:38 PM   #1545
Default Need some help
Hi all,
Need some help here, just got myself a TA04r, was happily building away when I realised that there's no space for a msc and another servo.
Thought I was gonna be cheap and use the msc from the other Tamiya I got. So is an esc the only way out or cld I perhaps drill a couple of mounting holes on the graphite deck?
Tronky is offline   Reply With Quote
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 07:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 06:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 10:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 04:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 08:39 AM
